1000 sold to Germany
Re: 1000 sold to Germany
Postby boilermaker » Mon Aug 17, 2009 3:18 pm
slippery
Bon Chance Mon Ami!
Georges
boilermaker
Postby SlipperySam » Tue Aug 18, 2009 1:01 pm
Merci Georges, you say it like I might need it! Only done 100 miles so far.....
SlipperySam
Postby boilermaker » Tue Aug 18, 2009 2:54 pm
slippery
Not at all mon ami. The only thing I would say is to check all the rubber components as they are of the rapid perish variety (european rubber seems to have this problem) if you look at one of my posts it mentions a vacuum hose x2 from the air filter box to the induction stub. This one will give you a real pain in the ass so check it before you do any real miles.
Chaudronner
boilermaker
Postby SlipperySam » Tue Aug 18, 2009 4:13 pm
OK thanks. I noticed that the rubber boot on the rear brake slight swich had perished which I repaired with self amalgamating tape. Changed the oil tonight and and found lots of particles stuck to the magnetic plug. Is the oil filter common to any cars? (Thinks, they might be cheaper....)
SlipperySam
Postby boilermaker » Wed Aug 19, 2009 1:18 am
slippery
If you look back through previous threads you will find a listing for all consumables except air filters and even a how to do it /make your own washable air filter thread. I know that one of the BM models use the same oil filter and K & N make one but neither of them are cheaper. I have a feeling that whatever filter you use it must incorporate an anti-drain back system due to its operating angle. This is standard fitting on a number of filters.
boilermaker
Postby stinkfeet2000 » Fri Sep 11, 2009 5:06 pm
SlipperySam wrote:Still looking for a new 1000S but found a new SF in hideous orange. Does anyone know the list price these were being sold for when MZ were still in business?
Do Grahams still have parts for the MZ1000S?
stinkfeet2000
Postby GED » Sat Sep 12, 2009 11:16 am
yes grahams will get the part from the factory if hes not got it in stock,bits ive ordered so far ,plugs,coils,filters,sprocket,all arrived next day ,infact ive found it easier and quicker to get parts for the mz than my yamaha yzf750
GED
Postby johnny2tents » Thu Oct 21, 2010 4:22 am
Hi Chaps,
Trend continues? Tuxracers old bike (SF same colour as Geds) was sold by the dealer in Inverness and has gone back to Germany.
Regards J2T
johnny2tents
Postby GED » Thu Oct 21, 2010 11:31 am
johnny2tents wrote:Hi Chaps,
Regards J2T
how much did it go for any idea
GED
Postby CharlyB » Fri Oct 22, 2010 3:59 am
It´s mine now :-D
@slipperysam Please check the camshaftchainscrew hope that is the right translation a lot of owners had problems with it, it could destroy the motor !
you could see some pictures here :
http://17787.forendienst.de/show_messages.php?mid=4601424&page=13
Hope that helps !
Cheers
CharlyB
CharlyB
Postby SlipperySam » Sat Oct 23, 2010 6:38 am
Thanks CharlyB I'll check that out. The bike is just about to be laid up for the winter so I'll leave it until then.
SlipperySam
Postby iceman » Sat Oct 23, 2010 8:56 am
CharlyB wrote:It´s mine now :-D
Hope that helps !
Cheers
CharlyB
That's only the second one I've read about on the German site and they made lots of noise before they had problems.
Personally I wouldn't go taking off the side cover to look at a screw unless I heard noises. viewtopic.php?f=2&t=3786
It would take more than that little screw to destroy one of these motors. :-D
As far as I can tell this is very isolated...
John Lennon
iceman
Postby CharlyB » Sat Oct 23, 2010 5:02 pm
Hi Iceman,
in the meantime we discussing that "Screwproblem" on page 19 !!! We have had 2 destroyed motors and a lot of loose screws
It doesn´t matter which year of production or how many miles but it´s up to everybody themselves to check it or not.
Good luck to you.
Cheers
CharlyB
CharlyB
Postby iceman » Sun Oct 24, 2010 12:45 pm
CharlyB, Just don't over do it on that little screw or you could be creating a trouble that didn't exist...too tight=snap :shock:
John Lennon
iceman
Postby boilermaker » Mon Oct 25, 2010 2:51 am
iceman
I think your point re over-tightening should be well taken by all, especially when dealing with a steel screw threaded in to an Aluminium/Aluminum casting. One of the threads on the German website seems to advise the use of a thread locking compound rather than an increase in tightness or thread loading. I can see this as a viable alternative provided both the screw and casting threads are THOUROUGHLY cleaned prior to application of the compound and the screw tightened to the correct torque figure (allowing for the lubricating action of the wet compound) when re- fitting. Cam chain tensioner problems seem to have been a recurring theme over the last 40 years or so, most manufacturers seem to have had a problem at some time or other, Makes you wish for an old bevel drive Duke!
boilermaker
Return to 1000S
Users browsing this forum: Bing [Bot] and 110 guests
