some corrections about the bike:
its definitely 2002, not 2001. paperwork had both numbers in various places, but title says 2002.
i misread the odometer, it is actually 38.1 kilometers (not 381 miles)
on 10/3/07 its logged to have had the carburator cleaned, a spark plug, and oil replaced.
it was stored with fuel stabilizer in the tank, which is probably why i was able to start it in the first place.
since the stabilizer was there all along, could the carburator still be gunked up?
someone told me a long time ago that if youre able to start the engine and let it run for a while, whatever gunk is in the carb gets cleared out by simply running.
is that inaccurate?
now on to some good news and some bad news.
the good:
i resolved the starting problems by adjusting the throttle lever cable.
it now starts with a simple button press and no airflow tricks.
the bad:
the dripping continued but since it was coming through the (now secured) vent hose i waited to see if it was just some excess, and would slow down and go away on its own.
a couple of minutes into it it actually did stop, but resumed elsewhere, up the frame.
i traced this up to another hose, which i think is the one that Drew is talking about:
- DSC00666.JPG (71.54 KiB) Viewed 13379 times
i removed the tank and it didnt look like the tank had any effect on the hose at all.
only thing that i'm not sure about whethere the crack was there earlier today, or if it was created from some kind of pressure in the few minutes that i kept the engine running.
there are no hardware stores open here on sunday so i'll try replacing the hose tomorrow and go from there.
thanks for the help guys. for as long as the engine was running i have to say it was a pretty purr.
cant wait to ride this thing already..
