Enclosed rear sprocket drive
Postby nikitino » Sat Oct 31, 2009 8:28 pm
I recently took the chain and rear sprocket off my Country 500 and the rubber piece that that drives the rear wheel fell out of the assembly. I think this thing was originally glued in as i remember reading that to take it out, you can heat it up. My question is when i am reassembling the enclosed chain/rear sprocket and mating it to the rear wheel, do i need to glue this rubber drive piece back onto the sprocket or can i just set it in its place and remount the chain assembly? If you have to glue it, what kind of glue should i use? I'm talking about the rubber throwing star looking thing that mates to the rear wheel hub and drives the wheel.....
nikitino
Re: Enclosed rear sprocket drive
Postby djsbriscoe » Sun Nov 01, 2009 6:03 am
The cush drive rubber (as it is called) does not have to be glued in place. If it is too loose you should replace it. It is normally a snug fit in the sprocket carrier.
If the rubber is sound and not cracked you should get some more use out of it.
For suppliers do a forum search.
David.
Electronics tech by trade.
djsbriscoe
Postby DAVID THOMPSON » Sun Nov 01, 2009 11:52 am
the parts book for you
item 17
9656016000 Sterndämpfungsgummi £19.26£22.15
still in the uk dealers price list but they may or may not have them
Users browsing this forum: No registered users and 44 guests
