tomtom wrote:funny i was thinking the same thing, but just removing the cover and doing an alteration.
Iceman dyson special, hope you've patented it
what about making an air scoop further back or on either side of the radiator? that way the hose will be shorter.
LWS66 wrote:I'm surprised you have'nt drilled some holes in the cover or just removed it (keep the air temp sensor connected to the wire or the engine light will stay on), and done a K&N filter mod. You'll get better results doing all that first as it's still restricted and now is drawing air through a long rippled tube. Drawing/forcing cool air is a good idea (only helpful at higher speeds) but your still not getting everything out of her that you could be.
boilermaker wrote:John
Good luck with any improvements resulting from your works to the induction However you still have that politically correct crap stuck in the exhaust.
tomtom wrote:now where's that dyson. I could have sworn the tube stretched to the top of the stairssssssssssssssssssssss last week.
