i used the demo first and then purchased the program cos i liked what i saw and it worked out cheaper than a dedicated fault code reader [fcr]i used the software thats on the link above try the demo first,see if you like it ,obd 2 interface and lead i got off ebay ,the people i got the software from are very helpful [typical yanksboilermaker wrote:GED
Are you still using the demo softwear or did you purchase, if so which one? Also, will my laptop cope and where do I get a usb/obd lead.
GED wrote:im assuming the bike is running ok now,its just the ecu light that is on,if you remove /replace /certain parts on the 1000 the ecu will pick up on this and assume theres a fault with the bike ,and illuminate the light ,ie if you remove a relay and then replace it the ecu light will come on and stay on ,until the bike has gone through a set number of start ups /getting to temp / running for a certain number of miles,once the ecu has decided that theres nothing wrong it will go out,there is a primary and a secondry ignition in the pencil coil and if either or both have failed then throw it away theres no fix other than to replace it,also if you have a laptop get a obd 2 diagnostic lead and suitable software and you can do your own diagnostics ,[i learnt the hard way]if u have no laptop then get a good fault code reader ,i have tried to email you a copy of the mz manuall but the size exceeds my email account and i cant send it ,sorry
boilermaker wrote:Werner
Sorry mate just noticed your other post mentions South Africa, many MZs down there?
SIMPLE ANSWER NO ,IF EITHER PRIMARY OR SECONDARY FAIL THEN THE COIL IS USELESS,PS IM A LITTLE CONFUSED AS TO WHAT YOU MEAN BY NEW ECU SOFTWARETheQK1 wrote:"there is a primary and a secondry ignition in the pencil coil" if one of these two "primer - second" if not working will the bike still run?
Regards
Werner
Regards
Werner
