bloody leak
bloody leak
Postby smudge660 » Wed Dec 15, 2004 5:12 pm
my baggi has a leak coming from underneath somwhere but do you think i can find it. it's only a couple of spots but it's annoying me big style i've checked the drain plug but no joy .any ideas :?
Hated by many,understood by few
smudge660
Postby keithcross » Wed Dec 15, 2004 6:07 pm
There are lots of possibilities but look at the following first (the easy to fix items)
Sump drain bolt/sealing washer
Oil pipe bolt to frame
Oil pipe to engine (two allen screws)
Next try
Gearchange shaft oil seal
Gearbox out put shaft
next
Left and right hand outer covers.
Crankcase
These could be a pain if the surfaces are leaking.
Just had a thought, you dont have an automatic rear chain oiler fitted do you? If so it could be oil from that, try turning it down a bit.
Postby phlat65 » Wed Dec 15, 2004 10:09 pm
don't forget to check the vent tubes. did you just perform any maintenance?
Users browsing this forum: Bing [Bot] and 36 guests
