amahoser wrote: How do you access the filter on top of the needle valve?? Had the carb pretty much apart and I didn't see anything.
Jose Soriano
hb7 wrote:Bill, I think you can Alu weld that and then file it down.
All the best,
Henri
http://moto-science.com/
323-933-1366
skype shb777
billr wrote: The "grab" broke it off.
Luckily, I have a Tour I'm saving for "parts"...![]()
Anyone know if that can be brazed back on?
BillR
amahoser wrote:She Lives!
Its been a heck of a few months with Baghira issues... First was a worn Clutch, a week after fixing that, I blew out a fork seal.... fixed that and a week later the battery died.... fixed that and then I noticed the rear brake was worn.... fixed that and then I get this stumbling issue. I know, I know... all of it is just simple maintenance issues but sheesh!
Hopefully thats all for now... I wanna ride my baghira!
Yep, it was the float valve filter... I cleaned that as well as the filter in the gas tank. Gas tank filter wasn't too bad but it did have some small debris around it. Never knew about the float valve filter. My Kawasaki Concours does NOT have float valve filters... Wish it did, every once in a while I get stuck float valves in that bike. Gotta be careful of hydrolock but the Baghira does not have that problem.
Thanks to all that responded.
Jose Soriano
radiograf wrote:Whilst you have the tank off and emptied why not seal it. Over here in the UK you can by a product called Pet Seal. Its a 2 part resin which you pour into the tank to coat the inner surface to seal any rust and pinholes. I have also used the resin from a fiberglass repair kit in the past, just remember to remove your fuel tap and plug the hole.
Users browsing this forum: Bing [Bot] and 33 guests
