Skorpion carb petrol inlet spigot
Postby ajwebonly » Mon Aug 23, 2010 11:15 am
Is it possible to alter the angle ( rotate ) the petrol inlet spigot on the standard Skorpion carb? It seems that different bikes have this spigot angled in different directions, and on one of my bikes it makes routing the petrol pipe difficult as it points forwards and up, causing the fuel pipe to kink.
ajwebonly
Re: Skorpion carb petrol inlet spigot
Postby basser23 » Mon Aug 23, 2010 11:41 am
Mine points down..so I guess you could just move it...
basser23
Postby ajwebonly » Mon Aug 23, 2010 11:45 am
Yes my other bikes one points down. But how do you move it? It doesn't seem to rotate. Maybe it can be rotated once the carb is disassembled? Or maybe its a press in fit and set at manufacture?
ajwebonly
Postby billr » Mon Aug 23, 2010 2:19 pm
ajwebonly wrote:Yes my other bikes one points down. But how do you move it? It doesn't seem to rotate. Maybe it can be rotated once the carb is disassembled? Or maybe its a press in fit and set at manufacture?
I just had my carbs off for a cleaning. The spigot points forward on both mine.
I still have the set from the Tour on the bench (managed to break the float post :( ).
It looks to be a press fit. I was able to reposition it with a gentle twist and it still feels tight.
Bill R
billr
Postby ajwebonly » Tue Aug 24, 2010 10:37 am
Bill, thanks. I've tried a "gentle twist" and a "not so gentle twist" on both of my bikes, but neither spigot shifted at all, they both seem rock solid. Was yours dismantled when you twisted? I'm wondering if the small screw next to the spigot actually locks it in place?
ajwebonly
Postby billr » Wed Aug 25, 2010 6:57 am
ajwebonly wrote:Bill, thanks. I've tried a "gentle twist" and a "not so gentle twist" on both of my bikes, but neither spigot shifted at all, they both seem rock solid. Was yours dismantled when you twisted? I'm wondering if the small screw next to the spigot actually locks it in place?
Yes, I have the carbs off the bike. I doubt I could easily get to the spigot with them on the bike. The only screw in the vicinity on mine is one for the float bowl.
I forgot to say that my "gentle twist" was with a pair of 6 inch channel locks to get a bit of leverage (oops). The spigot will not move with just finger pressure for me, either.
billr
Postby ajwebonly » Thu Aug 26, 2010 3:41 am
Ah That sort of gentle. :lol: I'll give it a go, many thanks
ajwebonly
Postby hb7 » Thu Aug 26, 2010 11:35 pm
I used a long 8mm socket to move it...
hb7
Postby DAVID THOMPSON » Fri Aug 27, 2010 9:28 am
figure out where it needs to point
and do it once
moving it too much or to often may make it leak
Postby billr » Fri Aug 27, 2010 7:10 pm
DAVID THOMPSON wrote:figure out where it needs to point
and do it once
Thanks for the advice. This is definitely a "set and forget, don't do it again" task.
Bill
billr
Postby ajwebonly » Sat Aug 28, 2010 7:11 am
Success - ish.
After some soaking with gt85 the spigot on one of my bikes freed up and now rotates easily with finger pressure alone. I've been checking in a bike shop and found most spigots do actually rotate freely like this - the mechanic ( after nearly throwing me out for messing with all his bikes ) said they usually have O rings and are meant to rotate easily.
However on my earlier bike the spigot appears to be fitted slightly differently and I think is pressed into place as I can see a serrated edge where it enters the carb, like a splined shaft. No amount of force or soaking has got this spigot to budge at all. Luckily the angle on this bike isn't a big problem.
ajwebonly
Users browsing this forum: Google [Bot] and 18 guests
