Baggy Battery
Baggy Battery
Postby angustoyou » Mon Sep 13, 2010 2:59 pm
Ok, so I got the new Baggy home, and took the battery out to check the levels. After topping it up, I went to refit it, and couldn't see how it came out. It would only fit back in place, with out re-routing the cables, if the positive terminal on the battery matches the black lead.
Is this for real, do MZ use red for negative, black for positive? I've never seen this before, is this std, or has someone done something to it before me?
I'm very confused, as when I put the positive to red, as it should be, it popped the main fuse. The wiring diagram seems to agree that the colours are backwards.
What's yours like?
angustoyou
Re: Baggy Battery
Postby kman.45 » Mon Sep 13, 2010 6:29 pm
angustoyou wrote:Ok, so I got the new Baggy home, and took the battery out to check the levels. After topping it up, I went to refit it, and couldn't see how it came out. It would only fit back in place, with out re-routing the cables, if the negative terminal on the battery matches the black lead.
What's yours like?
Red positive, black/brown negative.
2003 Baghira 660 SM/E
2008 Ducati Multistrada 1100S
kman.45
Re: Baggy Battery
Postby iceman » Mon Sep 13, 2010 10:01 pm
[quote="angustoyou"]Ok, so I got the new Baggy home, and took the battery out to check the levels. After topping it up, I went to refit it, and couldn't see how it came out. It would only fit back in place, with out re-routing the cables, if the negative terminal on the battery matches the black lead.
What's yours like?[/quote
My baggy 2003 is the same as yours.I did a double take when I saw it. :shock:
John Lennon
iceman
Re: Baggy Battery
Postby angustoyou » Tue Sep 14, 2010 12:55 pm
Thanks for the replies. How very, very bizarre. :?
angustoyou
Re: Baggy Battery
Postby edec » Tue Sep 14, 2010 5:16 pm
2001 Baghira: Red neg. Black pos. with mine also.
01 Baghira
99 Ducati SS750
edec
Users browsing this forum: Bing [Bot] and 16 guests
