Pencil Coi;ls
Re: Pencil Coi;ls
Postby LWS66 » Tue Apr 27, 2010 9:10 pm
peaster wrote:
Anyone out there had any ECU issues on thier bikes........
Cheers .... :)
I've not heard of any issues, but I know of a dealer that put a battery charger on a long dormant showroom new 1000S without disconnecting the battery leads and ended up toasting the dash assembly somehow. :roll:
LWS66
Re: Pencil Coi;ls
Postby speedshop » Wed Apr 28, 2010 4:19 am
I'm only repeating industry standard advice: which is do not disconect th ECU when using electronic welding equipment. You are more likely to indroduce faults by disconnecting it. The ECU is very well protected. Its the disconnecting of it that causes tha problems.
speedshop
Re: Pencil Coi;ls
Postby iceman » Wed Apr 28, 2010 10:12 am
speedshop wrote:I'm only repeating industry standard advice: which is do not disconect th ECU when using electronic welding equipment. You are more likely to indroduce faults by disconnecting it. The ECU is very well protected. Its the disconnecting of it that causes tha problems.
Any chance you have a link to this ? I would be interested in reading it...Thanks
I will try a few Google terms and see if I have any luck. Could ask this guy http://www.the-ecu-doctor.co.uk/
John Lennon
iceman
Re: Pencil Coi;ls
Postby speedshop » Thu May 06, 2010 10:29 am
I have a look at this link, its not the one I wanted, but somewhere on that forum is the thread where all the info you need regarding welding and ecus can be found.
http://www.mig-welding.co.uk/forum/show ... php?t=4792
speedshop
Re: Pencil Coi;ls
Postby iceman » Fri May 14, 2010 1:42 am
speedshop wrote:well possibly- but they are very well protected, you are supossed to leave them connected if you have to do welding. The circuits are that well protected. Disconnecting them causes more problems.
With digital stuff you can bet your bottom dollar it ain't going to work on another model, its so easy to program it not to.
These two are interchangeable...http://www.apriliaforum.com/forums/show ... p?t=204842
John Lennon
iceman
Re: Pencil Coils
Postby Stephenonz » Sat Jun 05, 2010 6:27 am
Have just fitted a Valeo Peugeot coil to my 1000ST. My bike was starting to miss on one cylinder. Pulling the coils out I found the coil on the missing cylinder (left side) was rusted. The spark plug was also very sooty. I followed the instructions for Benelli coils and it has worked a treat, see link below:
http://www.engenia.com.au/08_FuelIgniti ... Coils.html
The coil on the left is a Peugeot coil, the one in the middle my modified Peugeot coil, and the one on the right the orginal MZ coil
Stephenonz
Re: Pencil Coi;ls
Postby boilermaker » Sat Jun 05, 2010 2:49 pm
Stephen
Thank you for that brilliant link. All the info in one shot.
boilermaker
Re: Pencil Coi;ls
Postby Stephenonz » Sun Jun 06, 2010 4:02 am
I meant to include a photo showing the corrosion on the left hand side coil. I think the left side may be prone to rusting faster as it is the low side when the bike is on the side stand. The right side also has some corrosion, but it was not nearly as bad as the left side.
Stephenonz
Re: Pencil Coi;ls
Postby DAVID THOMPSON » Sun Jun 06, 2010 11:03 am
here is a pdf of the how to link
1000 coil info 1.PDF
(540.43 KiB) Downloaded 926 times
Re: Pencil Coi;ls
Postby tomtom » Sun Jun 06, 2010 4:49 pm
tomtom
Re: Pencil Coi;ls
Postby Stephenonz » Sun Jun 06, 2010 11:23 pm
Thanks, an interesting comment, is it ACF-50 Corrosion Block Grease: http://www.acf-50.co.uk/
Stephenonz
Re: Pencil Coi;ls
Postby tomtom » Mon Sep 06, 2010 4:15 pm
tomtom
Re: Pencil Coi;ls
Postby MJ310 » Mon Sep 13, 2010 9:23 am
If you search ebay for a GENUINE PEUGEOT 406, 407, 607 AND 807 V6 IGNITION COIL listing no 110426546899 these will fit once you cut off the collar and file it smooth.
Look at http://www.engenia.com.au/08_FuelIgniti ... Coils.html
This works as that is what I did after my coil failed, make sure you get the old type coil as I do not know if the new type fit as they are a different length.
Mick
MJ310
Re: Pencil Coi;ls
Postby tomtom » Sun Sep 19, 2010 4:59 pm
tomtom
Re: Pencil Coi;ls
Postby boilermaker » Mon Sep 20, 2010 4:46 am
Tom
What do the 675 coils retail at?
boilermaker
Return to 1000S
Users browsing this forum: No registered users and 153 guests
