oil filler cap
oil filler cap
Postby finn954 » Sun Apr 17, 2011 2:55 pm
where did they hide the oil filler cap and how much oil does it hold?
finn954
Re: oil filler cap
Postby rodge70 » Sun Apr 17, 2011 3:14 pm
filler cap near headstock,oil in frame,and screws for seat i think ikea have been mentioned on here,do a search failing that grahams in taunton will have them.
rodge70
Re: oil filler cap
Postby Skorpion660 » Sun Apr 17, 2011 4:25 pm
rodge70 wrote:filler cap near headstock,oil in frame,and screws for seat i think ikea have been mentioned on here,do a search failing that grahams in taunton will have them.
The description you've given is for a 500 Rotax re the oil filler cap, but if you have a 660cc then lift off seat where you'll see the white plastic oil tank and filler cap is at rear.
Terry
Skorpion660
Re: oil filler cap
Postby DAVID THOMPSON » Sun Apr 17, 2011 4:46 pm
the 500cc rotax and 660 yamaha are dry sump motors
do warm up motor and check on center stand warm
engine off so no blow out of the fill hole
be careful about getting too full
Re: oil filler cap
Postby Fluffy_Dog_1018 » Sun Apr 17, 2011 8:20 pm
As stated the oil "tank" is under the seat on the 660 with the filler cap at the very rear (near the tail light). I don't bother with the dip stick on the filler cap instead I hold a small flashlight right against the plastic tank and the oil level is easy to see. There are min and max lines on the tank, a dab of paint or permanent marker will make the marks stand out for easy reading. As Dave said just do a search on the subject and you will find much information.
Somthin ain't right.
1982 Yamaha Maxim SOLD
2001 Suzuki SV650 SOLD
2001 Kawasaki Concours SOLD
1983 Honda CB650SC SOLD
1996 BMW R1100R
2001 MZ Traveller
Fluffy_Dog_1018
Re: oil filler cap
Postby breakwellmz » Mon Apr 18, 2011 1:39 am
The oil filler cap on a Mastiff and Baghira is on the front right-hand side of the frame on (or near) the headstock.
Re: oil filler cap
Postby rodge70 » Mon Apr 18, 2011 6:04 am
chaps earlier post mentions baghira,so i assume the oil filler relates to same bike,which is near headstock
rodge70
Users browsing this forum: No registered users and 80 guests
