Fitting Advice for Twin Leader for a Trophy Sport (or TS)
Postby moriniboy23 » Wed Dec 01, 2010 6:03 pm
Ive got a Honda twin-leader and a CZ one, either of which drop into the MZ TS hub off the bike, but both look like they need 'reversing' so that the brake cable comes over the axle rather than under it, like the original single-arm brake. Effectively im having to turn the brake upside down to get it to work. Si?
Will this be OK? Anyone care to talk me through the conversion
Simon
moriniboy23
Re: Fitting Advice for Twin Leader for a Trophy Sport (or TS)
Postby Darklord » Tue Feb 15, 2011 10:47 am
The TLS linkage needs to be on the left hand side of the bike , I used a honda cable and lever as well, the cable is routed right to left as on a Honda . :wink:
Darklord
Postby moriniboy23 » Sun Mar 27, 2011 5:53 pm
So what else is involved? Torque-arms, spacers etc? I cannot see how it can be done
moriniboy23
Postby Louis Mair » Tue Apr 26, 2011 6:23 am
I guess you've found what you need to know by now. However I can still offer a little moral support to anyone interested in fitting a Honda front wheel. The first point to note is that the Honda brake drum cannot be fitted to the MZ wheel. The MZ drum is 'deeper' (more recessed) into the hub. You can fit a complete Honda wheel.
There are two Honda wheels to choose from: CB 350 (8'' dia.?) or CB 175 (7'' dia.?). The Honda wheels have steel rims and the steering is worse though the braking is better. I have been told that it would be theoretically possible to lace the Honda hub to the MZ (aluminium alloy) rim.
To fit the entire Honda wheel is pretty easy. You'll need one spacer on the axle (spindle). You need to swap the fork legs to get the anchor on the other side. I recall making a long split and hollow spacer to adapt the MZ cable; a Honda cable is probably a good idea.
[27 April 2011: The above is based on fitting 18" Honda wheels to TS250/1 (5-gang / 5-speed). For the 7" brake there is a 5mm spacer on the left and a 21mm spacer (pile of washers) on the right. The 8" brake has no spacer on the left and what looks like a standard Honda spacer (with dust-seal) on the right. Both Honda wheels and the MZ one have the same rim width (i.e. use a 2.75x18 tyre).]
Like most of these projects the end result is immensely satisfying and of debatable practical value.
Louis Mair has been different things to different people. Now I am a writer: http://www.mz301escocia.blogspot.com
Louis Mair
Postby moriniboy23 » Sat Apr 30, 2011 3:03 am
Nope, Ive had no help on this, but thanks for putting me straight on it....
I ahve got a twin-leader CZ hub, I wonder if that might work instead, since I need a complete H*nda wheel, not just the brake-plate
moriniboy23
Users browsing this forum: No registered users and 73 guests
