This is what the bike does.
The bike starts great with choke when cold and on side stand. Then if I sit on it and turn the handle bar or pick up the bike the revs drop and it stalls.
The thing also seems to barely hold idle and surges like crazy @ low revs. Once you get it past 2K rpm in the lower gears it revs up fine.
I've read somewhere 7 1/2 turns on air screw, so I will try that next, but it seems excessive, I mean most bikes 3 is a good midway starting point.
I also suspect the cables are binding, I'll fix that. But anyone else have any other suggestions ? This bike ran fine with the exception of a choke that didn't work. Now that has been fixed perfect to the extent it works better than anythign else in the carb.
Thanks.
Srinath.
