Pencil Coi;ls
Re: Pencil Coi;ls
Postby tomtom » Sat Dec 11, 2010 5:55 pm
tomtom
Re: Pencil Coi;ls
Postby Stephenonz » Mon May 16, 2011 3:31 am
Hi TomTom, I'm looking at using your suggestion re using 675 coils on my MZ 1000ST (I think one of my recently fitted modified Peugoet Valeo coils has just failed. Can you give me some pointers on the wiring connections please. Thanks. Stephen (NZ)
Stephenonz
Re: Pencil Coi;ls
Postby tomtom » Thu May 19, 2011 8:27 am
tomtom
Re: Pencil Coi;ls
Postby Stephenonz » Thu May 19, 2011 4:04 pm
Thanks for the fast reply, I've ordered the parts. I was also wondering about the wiring, i.e. which wire goes to which pin at the coil?
Stephenonz
Re: Pencil Coi;ls
Postby tomtom » Sun May 22, 2011 2:41 pm
tomtom
Re: Pencil Coi;ls
Postby Stephenonz » Sun May 22, 2011 10:24 pm
Thanks. Can you confirm which pin on the 675 Denso colis is +12V, and which goes to the CPU. Looking at installation instructions for the Cordona quick shift, the +12V appears to be the left pin: http://www.cordona.net/installations/pd ... 202011.pdf
Stephenonz
Re: Pencil Coils
Postby Stephenonz » Sun Aug 07, 2011 11:12 pm
Hello all. I've done the Denso coil modification (finally). The Denso connectors came quickly from Corsa in the US (as per recommendation from Tomtom, htttp://www.corsa-technic.com/item.php? ... gory_id=55 and the 675 coils from the US were as cheap as chips.
I didn't want to cut the wiring loom so I made up some short leads using the Corsa connectors and the Valeo pencil coil connectors, which I cut off.
Pictures are attached, the first shows the soldering on the Velo connector and the second shows the epoxy covering the soldered wire and split flex.
I fitted the leads this morning and the bike fired up with no issues.
Stephenonz
Re: Pencil Coi;ls
Postby Mach IV » Thu Feb 12, 2015 3:16 pm
NGK stick coils: 48031
Mach IV
Re: Pencil Coi;ls
Postby Mach IV » Fri Sep 27, 2019 12:30 pm
So the Denso coils for the Triumph 675 work?
Mach IV
Re: Pencil Coi;ls
Postby Mach IV » Fri Oct 04, 2019 10:12 am
Got some Denso coils but need color codes for wiring.
Could someone please post it up?
Mach IV
Previous
Return to 1000S
Users browsing this forum: No registered users and 131 guests
