Skorpion Front Brake Disc Query
Postby Ballacraine » Tue Feb 08, 2005 12:39 pm
Hi All,
I have a '96 Skorpion Tour
One of the problems I had when I got it, was that the front brake caliper was seized on the two inner pots. I freed them off OK, but the damage was already done... The disc has been pushed over.....Dished, if you like...I priced up a replacement from the UK importer...Comes in at over £90 + VAT + P+P
Please does anyone know of discs from other bikes that fit...or any other info (part nos. sources etc) on compatible replacements...Brembo or whatever?
TIA
Nige.
Sanity is in the eye of the beholder!
Ballacraine
600
Postby mcmoto » Wed Feb 09, 2005 1:33 pm
It has been said (on this list) that Yamaha 600's front calipers work.
Please, Someone verify.
Kelly
01 Aprilia Falco Fighter
"the Cylon Falco"
01 Skoripon Project...
mcmoto
Re: 600
Postby Dezmo » Wed Feb 09, 2005 2:49 pm
mcmoto wrote:It has been said (on this list) that Yamaha 600's front calipers work.
its the discs, not the calipers that work, and afaik, this is only for the baghira/mastiff...if the skorp uses the same front disc, then it should fit that too
Hella Yella, coming ta getcha!
Dezmo
Postby Ballacraine » Thu Feb 10, 2005 12:05 pm
'Whysub' informs me that the brakes on the Baghira & Skorpion are different.
The Skorpion part number is 9013164000. If that helps anyone to identify it.
TIA
Nige.
Ballacraine
Postby keithcross » Thu Feb 10, 2005 1:45 pm
Baggi SM and hence R6 sized disc part number is 9014268000. This signifies that the R6 disc will not fit. It is however the same part number as the Mastiff with ally wheels fitted.
Postby Ballacraine » Fri Feb 11, 2005 10:05 am
So no known alternatives to the original part then?
Nige.
Ballacraine
yes..
Postby mcmoto » Fri Feb 11, 2005 8:14 pm
Ahh, who will answer the the great rotor question??? :roll: :smt117
Kelly
"the Cylon Falco"
mcmoto
Postby chrisa » Sat Feb 12, 2005 4:51 pm
EBC makes a brake rotor for my '02 Traveller, which should be the same as the Tour. Do a Google on EBC and you should find the UK distributor, which is where I was able to find mine. It's usually a special order so it will take a few weeks.
Good rotor though and great folks to deal with.
Chris
chrisa
Postby Ballacraine » Mon Feb 14, 2005 4:02 am
Thanks a lot, Chris.
Useful information there.
I shall do that!
Nige. :)
Ballacraine
Postby Ballacraine » Mon Feb 14, 2005 4:09 am
Checked up!
http://www.ebcbrakesdirect.com
Yes they do it....
but....
About £40 more expensive than the OEM part! :P
Unless anyone else has any suggestions, looks like I will have to bit the bullet on this one.
TIA
Nige. :?
Ballacraine
Postby Doctor d » Mon Feb 14, 2005 4:38 am
If you are in the UK ring BSA Regal, 02380-366404. They are a UK importer of MZ's and spares, I have used them many times and find them friendly and helpful, and they usually get the stuff to me next day....
The Doctor
The Doctor
Big Bloke On A Big (Red) Bike Wiv Ickle Wheels
Doctor d
Postby keithcross » Mon Feb 14, 2005 6:24 am
The only alternitive is to get you steel rule out and go to a bike meet or shop and measure up some brake rotors on other bikes. You might get some funny looks, but if it saves money its worth it.
I would look at the Yamaha range first.
Postby Ballacraine » Wed Feb 16, 2005 12:12 pm
Thanks..
Yeah I know about the importer. That is who I got my quoted price from. I have dealt with them on a few occasions and have always had decent service. I just wanted to see if there was a more reasonably priced option.
I take your point about autojumbles, but we don't get many, if any, over here. Might have to try the steel rule trick yet. :wink:
Thanks again for input, folks.
Nige. 8)
Ballacraine
Postby mz660r » Thu Feb 17, 2005 7:14 am
look on ebay there are mz parts on now for low prices
http://motors.search.ebay.com/_W0QQsassZxtreme660
2001 mz 660 skorpion
mz660r
Postby Ballacraine » Thu Feb 17, 2005 12:09 pm
Yes, thanks for the link but......
That's fine if you happen to be in America! :(
By the time it is shipped over it will not be viable, I would think.
Nige :?
Ballacraine
