Bill Jurgenson wrote:let me add that the majority of users are civilized street riders. They got the TCIP4 because the low and mid range runs much better with almost no chainlash.
Bill Jurgenson wrote:quite simply, it is physically plug and play.
As bought from Ignitech, neither the MZs nor the SZR will run. You have to change the settings.
I will gladly supply the "map" I use and the Sparkers I deliver are definitely plug and play.
The TCIP4 will work with any battery ignition with inductive pickup like the Yamaha engine has. I have also supplied one- and two-channel CDIs from Ignitech for SZR, TDR and Aprilia RS125.
Somehow I thought after so many postings over 3-4 years, I had been sufficiently clear about the TCIP4.
I use and used it in all of my Skorpions and SZR and have delivered over 100 of them in Europe but also the US. and even OZ.
edfmaniac wrote:I just purchased one from Bill and live in Texas. It takes a few weeks but it's worth the wait although my particular bike was happier after modeling the bottom portion of the curve closer to the stock box. The mid range and top end are much better and you can rev to the moon. Mine came with the limiter set at 9500 but I changed it to 9000 just to ease my mind. Maybe after the cam, 11:1 Weisco and 686 bore, I'll want that 500 rpms back.
Users browsing this forum: Bing [Bot] and 26 guests
