starter relay
starter relay
Postby mz660r » Fri Feb 18, 2005 5:02 am
hello all. i put my bike back together this past few days and i noticed that the bike is not running. seems like the stater relay is not working. i did a bypass and got the stater motot to crank but i got sparks frm that. what can i do to test out the starter relay or fix it. does not seem repairable. thanks
2001 mz 660 skorpion
mz660r
Postby phlat65 » Fri Feb 18, 2005 10:32 am
I assume you have checked the interupt system? handle bar kill switch, side stand switch..
check the resistance of the pull in coil, I would guess it is around 20-40 ohms.
does it click when try to start?
that will get you started :lol:
Postby DAVID THOMPSON » Fri Feb 18, 2005 12:46 pm
yamaha relay part number 4KD-81940-00
is a direct replacement on my mz rt125 about $28 usd at
aftermarket atv shop
it may also work on your bike
unhook battery when changing
ar dave
Postby mz660r » Fri Feb 18, 2005 3:32 pm
i'm not getting any power when the relay is installed. a few days a ago it was clickinh alot when i try to start it i asumed cause the battery was low. but it rode fine then i took apart the bike and tried to start is with no luck the killt switch on the handle bars is run and the kick stand is up tried to start it but absolutely no power. only time i had power to the starter was when i bypassed the relay and directly had the wires connect.
ote="phlat65"]I assume you have checked the interupt system? handle bar kill switch, side stand switch..
that will get you started :lol:[/quote]
mz660r
Users browsing this forum: Bing [Bot] and 25 guests
