Mastiff CDI
Mastiff CDI
Postby Garyd1 » Wed Apr 18, 2012 12:43 pm
Anyone got one I could borrow to see if mine is shot? It is a TNDF 13 for a 02 plate Mastiff.
Garyd1
Re: Mastiff CDI
Postby den » Wed Apr 18, 2012 3:54 pm
Garyd1 wrote:Anyone got one I could borrow to see if mine is shot? It is a TNDF 13 for a 02 plate Mastiff.
Thats a big ask mate , ?What if the problem that shot yours is still there and soots mine , Makes sence!,
Whats happening , no spark , all of us may be able to help narrow things down , :cry:
den
Re: Mastiff CDI
Postby Garyd1 » Wed Apr 18, 2012 4:19 pm
Yes no spark, forgot to say also happy to buy one!
I have power to the cdi/tci and continuity seems ok, and replaced the annoying diodes. Also checked the resistance of the stator but not an expert in electrics but trying to learn fast...coil checks out Ok - am a bit stuck.
Garyd1
Re: Mastiff CDI
Postby den » Fri Apr 20, 2012 4:25 pm
so lets start from scratch ,I guess your not an idiot because you can use a pc , lol but sorry - i have to ask ,
HAVE YOU CHECKED ,
side stand switch
neutral switch.(this slots in a tiny slice on the engine casing) easily damaged
ignition switch
kill switch on the handlbar.(ewww)
crank sensor for the cdi box
all plugs and sockets for continuity,
100% good earth
There are topics on this forum about
"mastiff with no spark at all"
den
Re: Mastiff CDI
Postby Garyd1 » Mon Apr 23, 2012 5:05 pm
Thank you will check them through!
Garyd1
Re: Mastiff CDI
Postby den » Fri May 11, 2012 1:10 pm
Garyd1 wrote:Thank you will check them through!
Hope you report what the problem was if you have fixed it , :smt006
den
Users browsing this forum: Bing [Bot] and 33 guests
