traveller 96 rear brake master
Postby ilpadre » Fri May 04, 2012 4:15 am
i need a renewal kit for the master cylinder. I can´t find it anywere :cry:
per nielsen
denmark
ilpadre
Re: traveller 96 rear brake master
Postby djsbriscoe » Sat May 05, 2012 9:07 am
Try grahams motorcycles
Item 19 in this Fich
http://www.grahamsmotorcycles.com/2010% ... _Right.htm
HTH,
David.
Electronics tech by trade.
djsbriscoe
Postby ilpadre » Sat May 05, 2012 4:19 pm
I already made contact to grahams, They can not supply the repair kit. I just asked them about the complete master.
regards
Per
ilpadre
Postby mincehead » Sat May 05, 2012 10:17 pm
Utilise ANY other master cylinder with the same or `close` mounting points, there will certainly be a Brembo unit that will fit.
Maybe this one with 40mm spaced mountings:
http://www.intobikes.co.uk/products/001 ... =51&pt=192
mincehead
Postby therealche » Sun May 06, 2012 4:37 am
How about this lot?
http://www.teile-katalog.com/?ALIAS=254 ... 9021108000
That appears to be the complete piston assembly
http://www.teile-katalog.com/?ALIAS=254 ... 9021107000
Gasket set/ seal set?
therealche
Postby ilpadre » Sun May 06, 2012 11:18 am
Thank you all. Your advice has been most helpfull :D
Per
ilpadre
Return to Wanted
Users browsing this forum: No registered users and 106 guests
