baghira front fork seals
Postby handsomejackuk » Wed May 02, 2012 9:35 am
hi would anyone know if these would be the fork seals i need for my 2003 standard height baghira
http://www.marzocchi.co.uk/moto/528145.html
also been quoted a ktm part number
7528197
are these easy to replace is there any istructions on how to change them. i have never done fork seals before but usually do all my own bike maintenance...
also what weight oil would i need to use...
please advise...
al.
handsomejackuk
Re: baghira front fork seals
Postby handsomejackuk » Wed May 02, 2012 6:46 pm
thanks all for your help ..... :evil: :evil: :evil:
NOT>>>>>>##
handsomejackuk
Postby handsomejackuk » Wed May 02, 2012 7:11 pm
handsomejackuk
Postby DAVID THOMPSON » Wed May 02, 2012 8:12 pm
me thinks every one went for a ride
and shut off the confuser
Postby OLDMTNCARVER » Wed May 02, 2012 10:36 pm
Al,
No experience on the oil weight.
I found the same parts numbers that you posted also by nopantsflyer: (Searching) Interchangable part list, on 5-25-08.
The shop manual is only for the engine...
Here are the pictures provided in the parts list.
Yeah, I know... after the video that you posted I'm a slug... ( slug /snail ), this side of the pond it's all the same... :lol:
Figure the part numbers might help with parts purchase.
OMC
OLDMTNCARVER
Postby handsomejackuk » Thu May 03, 2012 4:41 am
thanks all.... its just a bit annoying... i am a member of another forum scooter... and the replies on there are almost instant.... i realise that its not checked so often nowadays as the bikes are getting a bit thin on the ground..
my local bike shop had a search this morning and found a set of 45 58 11 seals he said i could have for £12... so will try today to get the forks off and remove tha seals..
Al..
handsomejackuk
Postby Baggy-trousers » Thu May 03, 2012 6:15 am
No don't order those, I've just done mine. When I phoned up Marzocchi the guy there said they have just bought out some more advanced/updated seals that aren't on the website, phone them up and ask for the new 45x58x11 seals explaining they are for a bike and they will put you through to the right department. I installed mine a couple of days ago with no problems, all very simple to do. Don't hesitate to give me a shout if you are stuck with something, I'll try and get on here a bit more often!
p.s I put 10w fork oil in mine to help stop them being so squishy! (and you'll need a spanner/adjustable big enough to undo the 36mm nut on the top of your stanchions).
Baggy-trousers
Postby handsomejackuk » Thu May 03, 2012 10:55 am
awww bollux...
i just oredered a set of these from their website...
are these ok ?
AL...
handsomejackuk
Postby handsomejackuk » Thu May 03, 2012 11:03 am
Baggy-trousers wrote:No don't order those, I've just done mine. When I phoned up Marzocchi the guy there said they have just bought out some more advanced/updated seals that aren't on the website, phone them up and ask for the new 45x58x11 seals explaining they are for a bike and they will put you through to the right department. I installed mine a couple of days ago with no problems, all very simple to do. Don't hesitate to give me a shout if you are stuck with something, I'll try and get on here a bit more often!
got the right side leg brake caliper side all apart, and got the seal out to inspect... have ordered the seals... should be with me in a few days... this will give me time to rub the forks legs down and give them a nice new coat of painty,,,... any advice on reassembly would be useful..
i have not removed the stanchions off the bike as yet.. but dropped the legs, and undone the top nut to remove the damper cartidege... is there any need to remove the stanchions ?
or do i need to remove the stanchions to get an accurate fill of oily...
135mm i believe this to be... what is the best way to fill measure the oil i have steel rule and celipers... here... is this doen with springs and damper in or without. ?
Al...
handsomejackuk
Postby Baggy-trousers » Thu May 03, 2012 12:58 pm
unless you want to drop the bike right down on it's front end on assembly i would refit stanchions off of the bike (you have to push the stanchions into the legs far enough to allow you to pull up the dampers and rescrew on the top nuts/adjusters) after filling with oil that is! Don't worry about the measurement from the top of the oil just fill each leg with 580ml of oil, Grahams motorcycles worked the amount out. I was advised to get the newer seals, they are the same price! Hope all goes well for you bud.
Baggy-trousers
Postby handsomejackuk » Thu May 03, 2012 2:29 pm
cheers Bruv....
yeah i got the one side all off cleaned and sorted. just have a problem with the damper allen bolt on the bottom of the other fork... its real tight... i think i may even have rounded off the head...
have it turned upside down in my shed and filled it with penetrating fluid.. hoping i can get a good 8mm allen key bit to get it off tomorrow... most of my allen keys are worn.. so need a real good quality one and should be sorted if not will have to hammer a spline bit in there to get the bolt out...the heads are real shallow.. and the bolts are made of soft cheese.. i going to replace them with something a bit better...
Al..
handsomejackuk
Postby handsomejackuk » Sat May 05, 2012 1:35 am
Baggy-trousers wrote:unless you want to drop the bike right down on it's front end on assembly i would refit stanchions off of the bike (you have to push the stanchions into the legs far enough to allow you to pull up the dampers and rescrew on the top nuts/adjusters) after filling with oil that is! Don't worry about the measurement from the top of the oil just fill each leg with 580ml of oil, Grahams motorcycles worked the amount out. I was advised to get the newer seals, they are the same price! Hope all goes well for you bud.
when you filled with oil did you put the springs in ?
Al..
handsomejackuk
Postby cat » Sat May 05, 2012 5:09 am
Springs out. I did mine last year. Get the manual here: http://www.teamslipstream.co.uk/pdf/Front%20Forks%20Manual.pdf
(Why didn't you get the manual first?!) :o
cat
Postby handsomejackuk » Sat May 05, 2012 12:43 pm
cat wrote:Springs out. I did mine last year. Get the manual here: http://www.teamslipstream.co.uk/pdf/Front%20Forks%20Manual.pdf
i is a total dingbat and didnot read tha manual...but will do once i have finnished tha job...!!!
Al.. :smt005 :smt005
handsomejackuk
Postby rodge70 » Mon May 07, 2012 8:39 am
handsomejackuk wrote:cheers Bruv....
Al..
i used an air ratchet or you can use a battery drill on hammer action to shock the allen bolts loose,as for seals i used the ones supplied by grahams on my spare full height forks.
rodge70
Users browsing this forum: Bing [Bot], Google [Bot] and 21 guests
