Forks & Monoshock
From what I can find these are the 45mm Marzocchi Forks (Same as late 95-98 KTM). I have confirmed this is correct. I have also confirmed that a set of fork boots from a 1996 KTM 360 fits right up no problems
I've heard that people swap out the forks and triple trees for the YZ/WR forks... is there a specific year? Again, lots of threads mention it, but no pictures, and no specific information.
Front Brakes
I know there are hundreds of threads that discuss the p30/34 brembo caliper upgrades but most of them aren’t very clear if this is a bolt on affair on the BAGHIRA’s specifically. From what I understand there is a bit of issue with the spoked wheel and trying to clear it. There isn’t much discussion on if I need to purchase a new bracket or if I need to offset the front wheel at all. Can anyone clear this up? Can I just purchase the caliper and purchase a master cylinder later for the front? So far no answers
I've heard Beringer 4-pot Calipers will work, with a relatively easy stock steel home made bracket. But what bike manufacturer uses the beringer 4-pot? What modifications need done? Can you still use the stock Grimeca M/C with it? So far no answers
Here’s and example of the bracket for connecting to a Baghira: http://www.abload.de/img/100_01541d4x.jpg
Here’s an example of the P4 actually connected on a Baghira: http://img155.imageshack.us/img155/7194/imgp36265en.jpg
I've also heard of the Harrison 6-pot w/ the 6 seperate pads... I've spoken with a rep over there and they still sell the Baghi/Mastiff 6 pots.. They will want to confirm your bolt spacing and ensure fitment before purchase. Below is my email
RE: Caliper for 2003 MZ Baghira
mrbillet@mail.ndonet.com; on behalf of; mrbillet@billet.co.uk
Sent 22.5.12
Good morning Ameen,
Thank you for your email and image. Yes we still manufacture a 6 piston caliper to be a direct fit to the Mastiff. There was a cross over in years and to ensure we supply the correct fitment to you for your MZ Baghira, we would be grateful if you could advise us the distance between the mounting pitches and a photograph of the actual front end with the brake. The engineers can then cross reference the system and advise.
Yes we do ship to America.
prices are dependent upon finish and facia - for a MINI-6 BILLET ORIGINAL CALIPER WITH BILLET-6 FACIA SHOW POLISHED the price would be £284 plus shipment of £24.30 = £308.30 or Black Anodised or Clear Anodised £306.00 plus shipment = £330.30.
Our calipers are supplied complete, pads, pins, bolts etc and are a direct fitment to your stock front end.
I hope this is of assistance and await your advice.
yours
Janine
Harrison BILLET
Original Message:
Date: Mon, 21 May 2012 17:00:50 +0000
To: mrbillet@billet.co.uk
Subject: Caliper for 2003 MZ Baghira
Hello,
My name is Ameen, and I ride an MZ Baghira... (Same as Mastiff). I was wondering if you still make the 6-pot caliper that you used to make for the MZ brand that you once made at one time. I was interested in getting U.S.D. Price if I were to get this shipped here. Let me know!
[Description:
http://i49.photobucket.com/albums/f254/ ... ra%20Stree
t%20Moto/2012-05-19170801.jpg?t=1337485885]
A. Bakarè
Rear Brakes
Same for the rear… I’ve heard that I can upgrade to the p32f 2 piston caliper with ease and it’s a bolt on affair? Is this true for the BAGHIRA? I know this caliper looks like it’s used on most newer ducatis, aprilias, some KTM, and other bikes and can be found pretty easily in the US. I've never seen a picture with it on... at first glance, it looks like the inside pot casting will hit the spokes? No answers yet.
Frame Sliders and/or Case Savers (Protection)
Does anyone have any options for something to protect the cases? I’ve seen the stock cage that is made for the front and bottom of the frame but I have NO IDEA where I could get access to that. I have only seen pictures but have never seen any leads as to where I can purchase these.
Here’s an example: http://i922.photobucket.com/albums/ad70 ... aggy_b.jpg
Here’s another: http://i446.photobucket.com/albums/qq18 ... _FRONT.jpg
Do they have bolt on frame sliders I can bolt to the bottom run of the frame to protect my cases bottom of the motor?
Axle Sliders
I have read that for these we have to drill and tap the existing setup… Anyone have other alternatives, or possibly pictures of your setups?
Sprocket & Chain
There are some discrepancies on what the stock gear ratios on the Street Moto are. I’ve heard that the stock for the Street Moto was 15F and 45R, or 43R…. I am running 15/45 at the moment w/ a 112 link EK chain w/ a Screw Type Master Link. If you run 43 you can get away with 110, 47 you can do 116, and so on... I ran a 49 sprocket in the rear and honestly, it was too rev happy. IMO 45 is pretty nice... If you like to wheelie a lot in higher gears go 47.
Gas Mileage
I get from 31 to 45 mpg depending on how I ride w/ a 15/45 Sprocket setup. It's wierd because I get awesome gas mileage when I am doing the backroads romping on it... and if I'm just cruising around lugging it around I get a little crappier mileage!
Carburetion and Jetting
No information yet!
Helpful Links
Service and Factory Links
Factory Manual for Marzocchi Forks: http://www.teamslipstream.co.uk/pdf/Front%20Forks%20Manual.pdf
Factory Suspension Information: http://www.teamslipstream.co.uk/pdf/MZ%20Suspension%20info.pdf
Factory Parts Manual: http://www.teamslipstream.co.uk/pdf/mzdatafile.pdf
Factory Wiring Diagram: http://www.teamslipstream.co.uk/pdf/mzdatafile.pdf
Forum Links
MZ Riders Forum: http://www.mzriders.com
Aftermarket Parts Links
http://www.tunebike.de/
http://www.electrosport.com/site-map
Sump Guard: http://www.touratech-usa.com/Store/PN-040-1264/Sumpguard-MZ-Baghira-99-later
Sump Guard: http://www.off-the-road.de/Other-bikes/Engine-protection/OTR-Sump-guard-MZ-Baghira-Mastiff.html
Articles, Reviews and Informational Links
Great Article on Going from a SB to a Baghira: http://www.bobpickett.co.uk/bkit/muzbaghira.htm
Random Informational Links & Data
Can rock the KTM 950SM Mirrors: http://www.advrider.com/forums/showthread.php?t=201354&page=5
Oil Filter Part Number: Yamaha part # 4X7-13440-90
The stock spacers are 32mm ID,38mm OD and 50mm long, the ones i made are +20mm
Fork Oil Seal same as KTM360EXC Part# nr.7528197: http://www.mzriders.com/viewtopic.php?f=3&t=2421&p=14043&hilit=preload#p14043
Springs and Using 15w Fork Oil: http://www.mzriders.com/viewtopic.php?f=3&t=2780&p=15845&hilit=preload#p15845
Sprockets same as XT660: http://www.mzriders.com/viewtopic.php?f=3&t=5344&hilit=sprocket
rear: 200U-520-xx 36-50 tooth (Yamaha XT 600 1987-2003, XTZ 660 1991-1998, TTR 600 2004)
front: 342U-520-xx 14-16 tooth (Yamaha XT 600 1987-2003, XTZ 660 1991-1998, SZR 660)
Brembo P30/34 Front Caliper Interchangeable?
Brembo P32f Rear Interchangeable?
Rotors are Same as YZF R1 or R6
Turn Signals are Same as Ducati 1000ds
YZ450 Forks and Yokes fit but the wheels don't fit: http://www.mzriders.com/viewtopic.php?f=3&t=2298&p=13323#p13323
Aprilia RS250 or R6 front end can be Swapped: http://www.mzriders.com/viewtopic.php?f=3&t=2322&p=13349#p13349
Brake Adapter (Ktm) to use: http://www.mzriders.com/viewtopic.php?f=3&t=315
Brake Banjo Rear: The rear brake light switch is the same as BMW F650 -93 to 97 -M10-1mm
Marzocchi Interchangeability (1995-1998 KTM): http://www.advrider.com/forums/showthread.php?t=554545
The most Baller Baghi EVER: http://www.motorcyclenews.com/MCN/News/newsresults/mcn/2007/May/may-1-to-may-6/may0207mzpicturegallery/
Baghira/Brembo Brake Interchangeability: http://w.mzriders.com/viewtopic.php?f=3&t=1523&start=0
The brake....yep....it´s an Brembo P4 4 caliper brake, a Nissin 5/8 pump (from a Suzi TL 1000 or Yamaha R1 from ´02 etc.), custom made caliper adapter based on the SPIEGLER adapter, different brake line and a BRAKING 320mm disk. I´ve changed the pads to something better, SBS pads, art. number 566RS. They do their job very well. Spiegler don´t built the adapter anymore, so they send me the plans of it and a other firm made it for me. You must set the front wheel for ca. 2mm to the right because the disk slides at the fork if you don´t do that.
More Sprocket Information:
Renthal sprockets http://www.renthal.com/
Other Yamahas, same sprockets:
front sprocket: Yamaha XT 600, XTZ 660, SZR 660, SRX 400.
rear sprocket : Yamaha XT 550, XT 600, XTZ 660, XV 250, XV 125.
And...
http://www.jtsprockets.com/52.0.html?&L ... id=2532&p=
JT Sprockets Catalogue
Yamaha XTZ660 Tenere 3YF 1991 to 1995
Front Sprocket: JTF577
Rear Sprocket: JTR857
Front sprocket available in: 14, 15, 16 teeth
Rear sprocket available in: 38, 39, 40, 41, 42, 43, 45, 46, 47 teeth
That's it for now! Sorry if it's a lot!!!!
Meeners
