Malaysian - MZ 125SM
Postby biolator » Fri Feb 18, 2005 2:52 am
Any malaysia user here?
need some information where the best place to get cheap spare part and accesories for this bike...
-zaki-
biolator
Postby jbthumper » Mon Feb 21, 2005 12:32 pm
In Kl u could try jln sentul(NKS) or Jln Ipoh(gentali).
But the variety would be in singapore.
jbthumper
problem...
Postby biolator » Tue Feb 22, 2005 12:26 am
any usual problem on this bike? i'm having some problem the engine always turn off, even the engine is warm up....
-zaki-
biolator
problems
Postby DAVID THOMPSON » Tue Feb 22, 2005 1:15 pm
hi
check for dirt in gas
check kick stand safety switch
check right hand handle bar kill switch
check choke to make sure it is turned off when engine is warm
check fuses under seat may have one going bad
ar dave
Postby biolator » Tue Feb 22, 2005 10:49 pm
kick stand safety switch? i dont get it...
-zaki-
biolator
bike stoppage
Postby ptong » Tue Feb 22, 2005 10:57 pm
I had a similar problem and it truned out to be the choke sticking on. The plunger in the carburetor was actually rusty (almost brand new). I fixed it by taking off the tank and then manually pulling the cable whilst using a little wd 40 to loosen it up. I ended up loosening it and then with a bit of lubrication i shoulodnt have any issues.
Hope that helps.
ptong
ptong
Postby DAVID THOMPSON » Tue Feb 22, 2005 11:01 pm
on my rt125 it you put the bike in gear with the side stand down
the engine will die your's may or may not have it
look for electrical wires near the piviot point of side stand
it is required saftey device here in usa
so if you put bike in gear with stand down engime dies
if it is bad it can kill engine
ar dave
fan
Postby biolator » Wed Feb 23, 2005 3:33 am
one more question...
i need to know, how's the fan for the radiator work? it is always work when the bikes running... or it only on when the tempreature goes up. How to confirm the fan is working or not?
-zaki-
biolator
Postby micheleen » Wed Feb 23, 2005 6:07 am
The fan only runs when the coolant is approx 100 deg Celcius or hotter.
To test the fan you can run leads directly to it and check it rotates, the terminal connected to the black and yellow wire is +ve.
To test the thermal switch you need to remove it and heat it, checking the contacts close with a meter.This does entail draining the coolant first though :roll: .
Cheers, Mike
micheleen
Postby biolator » Wed Feb 23, 2005 11:20 pm
what do you mean the thermal switch? you mean the red LED indicator on the meter?
How frequent i should change the water coolant?
regards..
-zaki-
biolator
Postby micheleen » Thu Feb 24, 2005 4:52 am
The thermal switch is mounted into the back of the engine on the left hand side, it is what actually turns on the fan and the red temp warning light.
The manual recommends changing coolant every 2 years.
Cheers, Mike
micheleen
Postby biolator » Fri Feb 25, 2005 1:10 am
Anyone,
Got a list for each spare part that i should keep spare which is frequently need to be change and fix?
-zaki-
biolator
coolant
Postby biolator » Fri Mar 04, 2005 2:08 am
any one here got some idea / howto , to change the coolant?
-zaki-
biolator
Postby micheleen » Fri Mar 04, 2005 2:23 am
I just disconnected the bottom hose between the engine and the radiator, and drained into an old bowl. I used a new retaining clip when I reconnected the hose and then refilled with a 50/50 mix of antifreeze and water (the antifreeze must be suitable for aluminium engines)
Cheers, Mike
[edit] I think it took about a litre of liquid to refill
micheleen
Postby DAVID THOMPSON » Fri Mar 04, 2005 11:16 am
in the above post
retaining clip
equals
hose clamp in usa english
english is a wonderful langague 25 different names for the same thing
and 50 different spellings for each name
Return to 125 cc
