Raptor carb spacer from Moose Racing.
Postby edfmaniac » Mon Jul 02, 2012 12:05 pm
I just put one of these on my bike and thought I would share. The advertised hp gain wasn't expected up front but there's always hope, right. :lol: My first observation after removing the stock intakes and cleaning them up was that, when matched with the carb spacer, there was quite a lot of room to open up the intakes to match the spacer. I gained at least a 1/4" of overall dia. on avg. and cleaned up the flow substantially in my opinion. When checking the spacer against the head, the primary side matched almost perfectly but the larger secondary opening will require some additional porting on the head to be perfect. So in addition to added torque or hp, the spacer makes for a great tool to match the intakes to the head.
As for performance, I recently switched from a not so well maintained o-ring chain to a fresh standard chain and noticed a lot more improvement with that change than with the carb spacer. The spacer just seemed to make the engine run better at lower power settings so probably enhanced the torque more than anything. I'd recommend it if you have the spare change, time and ability to do some basic porting work. If you don't plan on matching the ports during the swap, I wouldn't bother with wasting your time or money on the spacer.
Re: Raptor carb spacer from Moose Racing.
Postby basser23 » Mon Jul 02, 2012 2:37 pm
thats interesting...i have a spacer,but have not mounted yet...also have a tunebike carb kit,as well as a new evr2 chain...also not mounted due to the "honey do list"
Seems I never have the time to do what I want to do.....anyway..i will get them installed this month....I hope..
basser23
Postby cabi3 » Wed Jul 04, 2012 7:32 am
hey man, how much was it?
also would you mind posting a picture of it fitted?
also also whofrom/do you have contact details?
im thinking about one but im not sure
thanks, cabi3
MZ Skorpion 1994, considering streetfightering it, but for now i am simply enjoying it
2X gilera cougar, each want new engines and one to be chop and one a street tracker,
I love chopping stuff to pieces
Its the putting back together which gets difficult
cabi3
Users browsing this forum: No registered users and 138 guests
