cat wrote:I know, I've often been tempted but it really is a rip-off. Although i did see something recently that said the tubing is very expensive and it is only sold in...hundreds of feet or something. (It is on superduke.net) But still, it needs those "heat protector" strips and he even suggests 2 heat protector strips for some applications. Some people have used some or other heater hose.
So, what is the tubing at Lowes and Home Depot for? Maybe I can find the same stuff here somewhere.
Oh and he even sells them as half length and full length - around the circumference.
I get from 31 to 45 mpg depending on how I ride w/ a 15/45 Sprocket setup. It's wierd because I get awesome gas mileage when I am doing the backroads romping on it... and if I'm just cruising around lugging it around I get a little crappier mileage
Tigerboy wrote:I get from 31 to 45 mpg depending on how I ride w/ a 15/45 Sprocket setup. It's wierd because I get awesome gas mileage when I am doing the backroads romping on it... and if I'm just cruising around lugging it around I get a little crappier mileage
I think you meant 41 to 45 mpg. I can't imagine 31 mpg, even in the worst case scenario. But it's true, I'd expect better gas mileage if you don't lug the engine. Keep the revs up, as they say.
Now, I'm trying to find the small foot-rest that bolts on the rear brake pedal. This bent when my bike went down and has since broken off. I've been to several bike dealers, and I've shown them the broken piece and ask if they have anything and the answer is always the same - the entire pedal needs to be replaced because on most dirt/dual sport bikes, it comes in one piece. I guess MZ is rather unique in that regard.
Anyway, there's just enough of the footrest left for my boot to claw on so I can still use the pedal, but it would be nice to replace it without having to replace the entire pedal.
edec wrote:The Husqvarna SMS 630 uses one that might be the same as the MZ. I'm eventually going to go the bolt route myself once mine finishes breaking off.
Good luck, Ed
den wrote:i challenge you to post a video on youtube of you pulling wheelies and general thrashing it around , i would love to see if you bike handles any different to mine ,dont know wether its just me but my baggie hates plodding along in traffic,,uses up first gear really quickly when you open her up on an open road , (bloody rev limmiter).plus , if i see someone else do it theres no reason why i cant , bikes are the same ,,so post on and provide the link,
just an after thought ,
photos in the gallery are fine but what about a sticky thread with links to members youtube videos ,
im gonna do a walkround of my pride and joy and post it also , so make a thread for me
DAVID THOMPSON wrote:my traveller has always had what i call bad mileage...
about 90 to 100 miles and fill it up ..
its cheaper to run my VW diesel car
but many things were modified on my bike when i got it ..
i have not had time to take off the carb and check the jets and see if its clean
and has the proper jets...i doubt it does as the picture in my
gallery shows it with an aftermarket pipe...
picture taken by the past owner..
not a fan of mods so told seller i wanted original pipe ...
so will probably be on the hunt for some stock jets for the original carb
or the ones Bill says work best for a stock set up
gallery/menu.php?gallery=members&album_id=9
Users browsing this forum: Bing [Bot] and 190 guests
