Choke Relocation on a Baggy?
Postby AtomicSpew » Thu Nov 18, 2010 12:07 am
I had a get-off in the dirt that resulted in snapping the little plastic nub off the choke dial that keeps the choke in place when engaging/disengaging the device. So, not a major deal, the choke still works, but you have to hold it in place now with one hand while turning the dial up or back with the other. I'm wondering if anybody's ever relocated the choke mechanism down to the carb with a lever-type switch?
_______________________________________
03 Baghira
03 CRF150F (w/BBR 175 hop-up)
Stop, drop and roll doesn't work in hell...
AtomicSpew
Re: Choke Relocation on a Baggy?
Postby Bill Jurgenson » Fri Nov 19, 2010 1:10 am
wha most do, is to simply let a short length of cable hang out under the plastic and put some sort of knob on it to pull. Of course you have to hold as long as you need it, then simply let it snap back in.
Postby nopantsflyer » Mon Nov 22, 2010 9:39 am
or you buy the choke for a xt600E model, must be from the model 1990-95 in the US, works great, only thing is you have to adjust the choke a little bit when you pull it out, otherwise the engine starts to rev up, michael
nopantsflyer
Postby AtomicSpew » Tue Nov 23, 2010 12:33 pm
Good tip--I'll keep an eye out on ebay for that unit--I couldn't find it on the parts microfiche on Bike Bandit, so maybe ebay's my only shot!? \
Cheers-
03 Baghira
AtomicSpew
Postby nopantsflyer » Wed Nov 24, 2010 12:19 pm
here is a link, http://www.georgiawatersports.com/Produ ... 30312d3030,
part #2KF-14371-01-00, in the micro fice it is number 49 if you look under carburetor, michael
nopantsflyer
Postby nopantsflyer » Wed Nov 24, 2010 12:21 pm
puts the choke right on the carb, no more cable and no more problems with moisture
http://www.yamaha-motor.com/sport/parts/home.aspx, thats what it looks on the carb
nopantsflyer
Postby AtomicSpew » Wed Nov 24, 2010 1:20 pm
Thumbs freaking up! I love this site. Thanks much for the link and pic!
Cheers!
03 Baghira
AtomicSpew
Postby handsomejackuk » Thu Sep 13, 2012 11:45 am
nopantsflyer wrote:puts the choke right on the carb, no more cable and no more problems with moisture
i want one of these where can i get one in uk for less than £70 ???
anyone know ??
handsomejackuk
Postby nopantsflyer » Thu Sep 13, 2012 4:29 pm
look on ebay, for used one or boats.net
2KF-1410A-00-00 PLUNGER, STARTER $35.40+15.95$ international shipping
nopantsflyer
Postby handsomejackuk » Thu Sep 13, 2012 5:21 pm
i try my local yamaha dealer tomorrow to see how much they are... we are thinking of going down on saturday for a run there..... so if they is reasonable i will buy one... i can't wait...
then i get rid of my choke cable... i have to next source a throttle only mechanism then for the other side, and make my own starter and stop button to locate else where...
the plan is to make a custom dash to hide behind my screen... this will house the cycle speedo, and the led lights i alsready have.. and also may wire up a fan overide switch and a trailtech tto temp guage...
handsomejackuk
