by stogadog » Wed Sep 26, 2012 1:10 pm
I have just sourced a TS 250 engine that hopefully is going to power my Trophy Sport project bike. It seems in good nick, has good compression and inside the crankcase looks clean and moisture free. I'm wandering is it possible to do the crank seals without splitting the cases or does it have to come to bits?
Cheers
Andy
stogadog
by Guesi » Mon Oct 01, 2012 3:21 pm
No, it is not possible on the 4 gear TS 250 and ES 250/2 engines.
Only on the 5 gear engines you can change them from outside...
by stogadog » Mon Oct 01, 2012 4:17 pm
I'm pretty sure it a five speed engine that I have got. Although saying that I'm not 100% sure. What are the differences visually ?(I'm not that familiar with the TS range)
stogadog
by therealche » Mon Oct 01, 2012 4:36 pm
4 speed engines have a head with vertical fins and a inspection plate in the top of the crankcase, 5 speed have the horizontal fins and no inspection plate IIRC
therealche
- Moderator
by therealche » Mon Oct 01, 2012 4:41 pm
5 speed TS 250/1
- 4 speed.jpg (54.24 KiB) Viewed 3712 times
4 speed TS 250
therealche
- Moderator
by stogadog » Tue Oct 02, 2012 3:18 pm
Cheers for that - I definitely have a five speeder then. Now I see the two together I realise I did know the difference after all but cheers anyway!
Time to get talking to my welding friend about how to get the engine properly mounted in the ETS frame I think.
stogadog
by therealche » Wed Oct 03, 2012 9:45 am
Make sure you keep it rubber mounted or it will shake your fillings out!
therealche
- Moderator
by stogadog » Wed Oct 03, 2012 10:34 am
Yes , been thinking about that. Hopefully going to get a bracket welded to the top tube so that the engine can hang off the TS mount as normal. Just have to make sure that the tank won't foul it. if that doesn't work I should be able to get some get some bosses welded on the crank cases so the original bottom mounts and silenblocs can be used. This all depends on how much persuading my welding mate requires though!
stogadog
