The ETZ is running rich (black spark plug) and runs poorly in lower engine revs - approx to half throttle where it then clears and picks up speed & runs as it should.
I've tried to adjust the carb with little luck - I can get it to tick over nicely (about 1200rpm) but anything less it becomes lumpy and won't idle.
Carb cleaned & checked and all appears well, timing & points gap is ok, new Champion plug fitted & air cleaner element clean too, all clips, rubbers etc are tight.
Is there a simple way perhaps to weaken the mixture via the pilot air screw without compramising tickover.
Presumably turning the screw out 'weakens' and in 'richens' the mixture.
Many thanks
Andy
