Namikuz wrote:So it has to do with the chain trying to make too small of a turn around and beats the shaft and bearing to death where as a larger front allows a smoother transisition around the gear and is getting less of a pulsation/ pounding from the single cylinder fireing, for the area of sprocket? or something like that....
Namikuz wrote:I see the clearence issue. Swingarm guard is GONE!!!! When I bought my Traveller and rode home to Salt Lake in Utah, from North Carolina, it had an 14 tooth front. I returned to stock, but it really made a differance in performance. I'll most likely go to a 42 rear and regain the pep it lost. top speed is also down about 5mph. wont pull past 90 now and had pulled almost 100 with the 14 tooth up fromt. 5k in elevation didnt help performance at all either!!! hehe.
Loving Emil Muz all the same!!! (Emil Muz is a"bad guy" charecter in the movie Dragnet with Tom Hanks and Dan Acroyd) TIME FOR An 10.5:1 720 KIT AND CAM!!!! YEE HAAAA!!!
DAVID THOMPSON wrote:leave it stock and buy a 1200 bmw cheap when some guy scares the crap out of himself on it ..
edfmaniac wrote:Namikuz wrote:I see the clearence issue. Swingarm guard is GONE!!!! When I bought my Traveller and rode home to Salt Lake in Utah, from North Carolina, it had an 14 tooth front. I returned to stock, but it really made a differance in performance. I'll most likely go to a 42 rear and regain the pep it lost. top speed is also down about 5mph. wont pull past 90 now and had pulled almost 100 with the 14 tooth up fromt. 5k in elevation didnt help performance at all either!!! hehe.
