rear wheel spoke sizes supermoto
Postby handsomejackuk » Mon Feb 25, 2013 11:08 am
does anyone know the spoke sizes for a rear supermoto rims... looking to have my rear wheel rebuilt shortly, and need the spoke sizes.. ?
handsomejackuk
Re: rear wheel spoke sizes supermoto
Postby handsomejackuk » Mon Feb 25, 2013 4:49 pm
i got a few things but need some more info... anyone know... what the model number of the behr rim is for a 17 inch supermoto.. and what make the rear hubs are..? i need to work out some measurements for spokes...
handsomejackuk
Postby handsomejackuk » Tue Feb 26, 2013 4:15 pm
anyone ?
handsomejackuk
Postby handsomejackuk » Wed Feb 27, 2013 11:58 am
ANYONE !!!!
handsomejackuk
Postby handsomejackuk » Wed Feb 27, 2013 2:35 pm
ANYONE !!!!!! GRRRRR GRRRRRR
handsomejackuk
Postby rodge70 » Thu Feb 28, 2013 5:06 pm
calm down,calm down :lol: think hubs are modified xt600 :lol: as for spokes and rims,no idea.
did have my rear re-laced under warranty as chrome spokes were fitted in rear,not stainless like the front and that was done by grahams.
rodge70
Postby breakwellmz » Thu Feb 28, 2013 5:13 pm
handsomejackuk wrote:Hi,
Why not ask Grahams?
Postby kman.45 » Fri Mar 01, 2013 11:21 am
why don't you get a caliper or ruler, drill bit, etc and measure them.. Besides, best thing you can do is put the next size bigger spokes on there. I broke five original spokes on my rear before I finally just sent the damn thing off to Woody's for rebuild, and they suggested larger than OEM size.
2003 Baghira 660 SM/E
2008 Ducati Multistrada 1100S
kman.45
Postby handsomejackuk » Sun Mar 03, 2013 7:36 am
phew.....
someone is out there....
i got a local bloke who is gonna relace them.. for £35.. he builds loads of wheels for classic bikes.. as for spokes i will probably order 3 off grahams as a pattern, then get a fullset from essex wheel builders or whatever they is called... think its about £65 so overall £100 for the full rear rebuild, i will polish rims myselfy, and get the hubbies painted here localish...
handsomejackuk
Postby handsomejackuk » Sun Mar 03, 2013 7:37 am
what size spokes did you get i believe they are 8 guage 4mm did you get the next size ?
12 = 2.60mm (.104” dia)
10 = 3.20mm (.124” dia)
9 = 3.60mm (.142” dia)
8 = 4.00mm (.156” dia)
7 = 4.45mm (.171” dia)
6 = 4.87mm (.192” dia)
5 = 5.15mm (.203” dia)
4 = 5.70mm (.224” dia)
handsomejackuk
Postby kman.45 » Mon Mar 04, 2013 9:53 pm
Damnit! you would have to ask. I won't be home for about a month, otherwise I'd go check.
kman.45
Postby handsomejackuk » Mon Oct 28, 2013 12:43 pm
i have got it off and on my bench ready to rebuild / respoke....
ouch..........!!!!!!!
i just dunno what to do... the hub is really shabby and needs a good service.. flaky paint... grrrr grrr
most of the sprocket side spokes are in very good condition, and think they just need a good clean, as for the other side seems to be a bit of a mish mash, some are good, some are rusty and just gone too far...
now my local wheel builder said he can rebuild my wheel, but ideally i would like to keep cost down, and learn how to do it myself...
i am about to measure the offset shortly as a reference in case i cock up....
was thinking of removing one at a time, and cleaning / replacing them, and measuring up and checking out the state of the scabby ones while i am at it, and maybe get the wheel builder to tighten and true the wheel for me....
or completely remove all spokes, and getting hub painted / powder coated, and upgrading spokes to next size up....
any advice..
PLEASE PLEASE....
handsomejackuk
Postby rodge70 » Mon Oct 28, 2013 4:30 pm
i would go with the above,may cost more but powder coated hub will look neat and last,only down side i can see is you may want to do the front to match :roll:
rodge70
Postby handsomejackuk » Mon Oct 28, 2013 6:10 pm
left a message with the wheelbuilder tonite. was a bit disappointed at first, as he said he doesnt do wheels anymore, i left a message and he got back to me to say he can rebuild it for me as he did my front a while ago...
Phew !!!!
Anyway i have removed all the spokes except for 4 that were seized so pretty good luck really...
have ground out the 4 seized spokes...
have seperated them all an checked on grahams site looks like the longer rear ones 172mm disk side are the same, and the sprocket side spokes are different...
so will fone and get a price on what i need tomorrow, i will have a good look to see if any can be reused, or may change the lot for next size up...
probably get them from essex whellbuilders..
I will keep you all posted on here on whats happening... hope to get the hub all cleaned up tomorrow for possibly powder coating or i may paint it myself as it turned out great on the front last time...
handsomejackuk
Postby handsomejackuk » Tue Oct 29, 2013 2:36 pm
have the rim polished up today, took a few hours, with the drill autosol, brasso, and some polishing mops but nearly there...
got my mate going to sand plast the rim on thursday. so that will be ready for paint...
just need to think about the spokes now...
I have a couple of options,,
I have 31 used nipples all good, the other 5 i have damaged and are no use...
bear in mind that these are 80 p each so come to £24 approx... so have saved a small bit there...if i can re-use them... i see no reason why not...
now the spokes i have had a look at, and not really worth salvaging any of them... they all have some pitting, and rust on them...
my options are
order a spoke of each type from grahams to check quality, and a nipple this is only a fiver so worth a punt...,
then if the grahams spokes are all good, and fit my nipples order just the spokes for £47...plus the odd 4 nipples
central wheel do spoke sets with nipples for about £69 dont really need all the nipples !!!! but they say they are imperial spokes. which i pretty sure my nipples and spokes already are...
there are some other companies doing spokes, and nipples but not entirely sure if i trust the quality....
another option is to go with central wheel components, and get next size 7 guage spokes and nipples for the same /£69...
this will require some drilling out of the rims, and hubs...
handsomejackuk
Users browsing this forum: No registered users and 147 guests
