Namikuz wrote:So.................... no answers for the original question? TDM box?
edfmaniac wrote:Namikuz wrote:So.................... no answers for the original question? TDM box?
You also asked for some education and trying to bypass the stock rev limiter because you don't like it to kick in 2000 RPM past max torque and 1200 RPM past max HP isn't going to do your bike any favors or make it sound any better. Peak HP is @ 6000 RPM. Peak torque is @ 5250 RPM. Maybe if you tell us more about what you are trying to accomplish, you will waste less time and money.
edfmaniac wrote:I hope you take all of Bill's advice on running these engines at higher RPM, and not just pick the parts you want to hear.That balancer drive gear is supposed to be a killer if you do a lot of down shifting into high RPM or pluck the clutch a lot.
Cheers
samandkimberly wrote:I've played with my Ignitech box a little and I find my preferences a bit different from what has been discussed here: for street riding I like the ignition to advance as soon as possible, then remain stable over the RPM range I use for riding - I've found this to give crisp, consistent throttle response. I think this is what Yamaha tries to do with their stock curve and it works for me. As far as rev limit - my weird motor (mostly stock intake and exhaust system, ported head, Hotcam 1 and 11:1 Wiseco) peaks well below redline but makes some power past it; its nice to have over rev on occasion and I'm sure I'm not damaging anything occasionally spinning up to 8k.
BTW, it's nice to be able to temporarily lower the redline to a lower RPM to check the accuracy of the tach. Mine seems to be right overall, but can vary plus or minus 10% or more.
I plan on doing some serious dyno time this spring, but I'd guess any gains will be small and will come from a small amount of retard, maybe a couple of degrees.
Sam
