Brake Fluid
Brake Fluid
Postby biolator » Thu Mar 24, 2005 5:40 am
For fuild, it is ok i use any type of dot 4 fluid for disc brake?
-zaki-
biolator
dot 4 fluid
Postby DAVID THOMPSON » Thu Mar 24, 2005 11:47 am
the shop manual i have say's dot 4 fluid on page 73
it also says dot 4 fluid on the top cover
of the front brake master cylinder
do not get the fluid on plastic and cover up your
speedometer face with some thing when working on the front brakes..
as in the past the fumes from it could fog the speedometer lens..
new type plastic may not do this but don't take a chance
Postby phlat65 » Fri Mar 25, 2005 12:05 am
yes, any dot 4 fluid is ok. it relates to the minium boiling point of the fluid, some are rated higher than others. the Motul 600 is the best, I use it in the off road bikes, and in my baggy.
just never use dot 5!!
Postby jbthumper » Sat Mar 26, 2005 2:36 pm
is there something wrong with DOT5 being used on an MZ??what about DOT5.1??
all i know is that DOT5 and above is that it won't spoil your paint job if u spill on them...
jbthumper
Postby phlat65 » Sat Mar 26, 2005 3:37 pm
dot 5 fluid is silicone based, NOT compatible with our rubber components. it will cause a brake system failure.
stick with a quality dot 4 like the Motul 600. only in a racing situation can you boil that fluid. :-D
Postby biolator » Sun Mar 27, 2005 3:59 am
phlat65 wrote:dot 5 fluid is silicone based, NOT compatible with our rubber components. it will cause a brake system failure.
i just buy a dot 4 brake fluid, when i want fill into the rear brake system, i just find out, the current fuel is total different form the new one i buyed. The new one, is more light. Is there any different fluid for the front brake and rear brake system? please advice..
-zaki-
biolator
Postby jbthumper » Sun Mar 27, 2005 4:13 am
did u check your brake pads first??because u shouldn't top up if your brake pads are worn...replace then...then u can see that the fluid level will go up...
but if your pads are ok...then u may top up...OR flush the old fluid and pour a
new. This would help keep your braking system in good form.
p/s:i'm loosing my front brakes firm grip because of improper maintainance...maybe the rubber mechanism in master pump is worn out...(sigh)
i miss my stoppies :cry:
jbthumper
Return to 125 cc
Users browsing this forum: No registered users and 44 guests
