clutch nut
clutch nut
Postby stephenh » Mon Apr 01, 2013 10:02 am
Hi all
can anybody tell me if the large nut holding the clutch hub in place on the rotax engine fitted in a silver star is a left or right hand thread please.cheers steve :D
stephenh
Re: clutch nut
Postby DAVID THOMPSON » Mon Apr 01, 2013 3:17 pm
THE CORNERS OF THE WRENCH FACE HAVE A SMALL CUT TO INDICATE REVERSE THREAD
LOOK AT THE HOSE NUTS ON A GAS WELDING BRAISING TORCH YOU WILL SEE THE SAME MARKS
SO THE HOSE IS ON PROPER fitting
note the little cut in the face of the nut in pic
left hand nut.jpg (6.25 KiB) Viewed 2852 times
Re: clutch nut
Postby stephenh » Mon Apr 01, 2013 3:27 pm
Thanks for that David,regards steve :D
stephenh
Return to 500 cc
