AND being riveted together........Surgury to re-pack.
Anyone re-pack an M4, that is assuming it is even able to be done.....
time to break out the DRILL!!!!!!!!! (naw, not just yet....)
den wrote:if both ends have rivets then its defiantly strippable,,mine was an American Johnson for whatever , i liked it purely because it was carbon fiber and the end had the correct 3 holes at the right spaces to fit my m4 type link pipe,,i would not have bothered if i didn't see any rivets in the add,lol , as soon as i got it i drilled out all the rivets and pulled it apart,,Its a straight through exhaust mind,i was left with outside cylinder , inner baffle tube and two ends,,i chopped off a "3 section of the cylinder and inner baffle , re-wound it with wire wool , bought some sweet(must be it was expensive) high temp silicone exhaust matting,and refurbished it,A good tip if your thinking of doing this ,
wrap the inner baffle with wire wool , very tight , about three turns,Then wrap the baffle with the high temp matting,,you need to be even when rolling and firm but not too tight , roll it till is just too big for the outer cylinder , now the good bit , Stick the whole baffle/wadding in a black bin liner(super thin ones that are useless as bin liners)and suck all the air out with a vacuum /Hoover,,get the picture, now slide the baffle in the bag inside the cylinder ,once your happy , poke the bag and let the air in , leave the bag in place , nothing will happen to it , mines still there ,, fit the end caps noting the orientation of the of the outlet tube direction and the bolt fixing holes , silicone seal and re river , job done ,
ps , i bought a stainless steel scorpion endcan that has the same bolt hole fittings for the m4 type link pipe if anyones interested,
den wrote:i posted this in a topic about my carbs and how to stop the backfire when de-cellerating,,turns out i just got to do a minor adjustment with the jets because ive now got a straight through exhaust and not the original that had a cat,,( theres a difference in back pressure).so listen to the video and make you own assessment.people have said the de-celleration backfire is normal(ish).in this video ive not modded carb yet
http://youtu.be/D93lnIOThtw
Users browsing this forum: Bing [Bot], Google [Bot] and 6 guests
