Skorpion rev counter problem
Postby UNNA » Fri Jun 28, 2013 3:01 am
My Skorpion rev counter swings to and fro like a pendulum. Is this likely to be in the rev counter or the sender unit? How easy is to get to the sender unit?
UNNA
Re: Skorpion rev counter problem
Postby dickl » Fri Jun 28, 2013 4:40 am
I used to call my rev counter "Lord Lucan" because it swung madly and then one day disappeared without trace!
dickl
Postby basser23 » Fri Jun 28, 2013 6:20 am
known issue with this tacho....not in sender unit which is coil,most likely in the tach itself...they are crap..what year skorp? There were 2 different tachs,early before '02 and after. later tachs were better,but supposedly not interchangeable with early ones...
basser23
Postby UNNA » Fri Jun 28, 2013 1:32 pm
It is a 1994. I have just bought it with 19,000 km registered. Presumably it has averaged 2000km a year. It is like new.
UNNA
Postby DAVID THOMPSON » Fri Jun 28, 2013 2:26 pm
take a look inside may need cleaned and some one that knows how to solder electronics
rework the circuit board
if its lived in an area where humidity is high it may have some bad joints in side
also check the relay 19 and relay 30 articles
this relay supplies power to the whole bike
it's relay 30 on the 660 bikes drawing
relay 30 powers the ignition unit it may seem to run ok
but the tach does not like the power being supplied so it goes nuts
on my rt125 the tach acted up for several days
then bike died
sorted it to bad relay 19
after replacement TACH problem went away
the contacts in the relay went bad
viewtopic.php?f=4&t=2085
watch the spade lugs on the wires they get weak and do not grip the wires
they also break off the wire ...wires in side the covering turn to green slime and all thats left is the covering
Postby UNNA » Fri Jun 28, 2013 4:03 pm
Thanks for that. I do live in moderately humid part of northern New Zealand so I will replace the relay and take the rev counter in for service. Is there a part number for the relay and where is the best source of them?
UNNA
Postby DAVID THOMPSON » Fri Jun 28, 2013 5:34 pm
its a standard light relay available at most auto stores
and a bit larger in physical size than the stock one
this one is 4 pins
the one i have is i think 5
Postby UNNA » Fri Jun 28, 2013 5:54 pm
Thanks David. Makes a change from getting all our old BMW bike parts from overseas.
UNNA
Users browsing this forum: No registered users and 93 guests
