What needs checking for tightness?
Postby duncmac » Thu May 30, 2013 8:51 am
Remember seeing a post on here about the ignition switch coming loose.
Mine was very loose lastnight on the way home.
So what else should I regularily be checking?
I'll check over everything I can see but are there any key/known places to ensure are torqued up nicely?
Ta
MZ Baghira 2002 - Silver
CBR 600 FY 2002 - Tri colour
duncmac
Re: What needs checking for tightness?
Postby DAVID THOMPSON » Thu May 30, 2013 11:54 am
the switch is the only major problem i know of
but the guy at my house that rides the bike needs tightened up some times
getting a bit loose here after 63 years up on 2 wheels :smt040 :smt023
Postby minto87 » Fri Aug 09, 2013 1:08 pm
This might sound daft but what did you use to tighten it?
Mine is a little lose, I was going to go find a small enough set of pliers? Its just one screw as far as I can see?
I'm terrible at mechanics, seriously you should see my past 125cc motorbikes , hence why I am here!
Gotta look after the baggy!
minto87
Postby DAVID THOMPSON » Fri Aug 09, 2013 4:29 pm
there are 2 of them and if there loose remove and replace with allen head screws and lock tite
do not want the switch to fall down and bind the forks
AND CHECK ALL YOUR BIKES AND SCOOTERS
these key sets are used on a bunch of brands worldwide
and tell all the riders you know
and yes there a beast to get to on a traveller
Postby minto87 » Sat Aug 10, 2013 4:59 am
Cheers David!
Appreciate the help :)
minto87
SPROCKET BOLTS!!
Postby jimc » Sun Aug 18, 2013 11:35 pm
Keep an eye on the sprocket retaining bolts.
These will quickly damage the drive hub if they loosen up .
1996 Skorpion Sport
1981 XT550 Yamaha
1989 KDX200 Kaw
1994 Duc 900cr
jimc
