CDI units
CDI units
Postby bikerbabe » Thu Apr 14, 2005 5:15 pm
Ok, brain picking time. On the back of my previous Failure to Start thread, it still doesn't start, and it's looking like it could be the CDI at fault. I'm going to test mine on another bike to be sure, but as I've been looking on Ebay today, I see loads of CDI units for other bikes.
Does anyone have an idea of which bikes have compatible CDIs and what would happen if I got one that fitted but wasn't compatible in 'electrickery' ways? :roll:
Thanks :wink:
Can't think of one.
bikerbabe
Postby keithcross » Thu Apr 14, 2005 5:34 pm
The CDI units from the following will fit.
Yamaha SZR660
Yamaha XTZ660
Any MZ 660
yamaha TDM 850 (watch the revs though as the rev limiter is set higher)
Postby jayded1 » Thu Apr 14, 2005 5:57 pm
Would you happen to know what CDI's fit a 125sx?
125 sx
In Bermuda
jayded1
Postby DAVID THOMPSON » Thu Apr 14, 2005 9:49 pm
if you find one for the 125's email me
as i have found nothing on the 125's except the starter relay
Postby F0ul_Oli » Fri Apr 15, 2005 6:30 am
keithcross wrote:The CDI units from the following will fit.
Yamaha SZR660
Yamaha XTZ660
Any MZ 660
The TDM surprises me - I always thought you needed the get the CDI unit off another bike with the same number of cylinders.
Another question I have is what year TDM? The ones after the 96 facelift have a different firing order to give a big twin noise!
Oli
F0ul_Oli
Postby MuzzinMo » Fri Apr 15, 2005 10:14 am
Hi there!
You should watch out for a TDM 850 3VD item, not for the 4TX series.
The rev limiter is set at 8400rpm, ignition some degrees earlier (38° to 42°...not tooo sur about the numbers).
Just have a look ebay, good luck.
Regards, Mirko
http://www.mzskorpion.de
MuzzinMo
Postby bikerbabe » Sat Apr 16, 2005 4:55 am
Thanks.............next question........anyone got one for sale at a decent price 'cos I tested mine on a mates bike and it's dead as a dead thing :cry:
:roll:
Can't think of one.
bikerbabe
Postby bikerbabe » Sat Apr 16, 2005 2:55 pm
Have found a great site with lots of stuff from Yammy 125's but I don't know what engine the SX has - is it a Yam of some kind?
Anyway, the site is http://www.cheshiremotorcyclesalvage.com/acatalog
and they've got everything but one for the Skorp :roll:
Can't think of one.
bikerbabe
Postby DAVID THOMPSON » Sat Apr 16, 2005 8:19 pm
the one from the 125 is not a yamaha part
i think its made by a company in Solovinia as oem part
for other bikes check
http://www.mz-b.de
they do replacement systems for old bikes
and old mz and jawa parts :-D
