TS125, throttle assembly removal
Postby ricklincs45 » Wed Sep 11, 2013 3:24 pm
Hi all,
I need to remove the twistgrip assembly on the TS - can anyone advise how to remove the bung in the end of the handlebar please?
Thanks,
Rick.
ricklincs45
Re: TS125, throttle assembly removal
Postby therealche » Wed Sep 11, 2013 5:39 pm
There should be a hole through the twist grip , turn the twist grip and you will see a screw holding the end plug. Remove the screw and the plug will pull out.
therealche
Postby ricklincs45 » Thu Sep 12, 2013 7:37 am
Ah! Thanks very much for that. :)
ricklincs45
