OUTPUT SHAFT SEAL
OUTPUT SHAFT SEAL
Postby ironhorse99 » Tue Oct 29, 2013 7:36 am
MY OUTPUT SHAFT SEAL TO MY 2001 TRAVELLER IS LEAKING SO I WENT TO MY LOCAL YAMAHA DEALER AND PICKED ONE UP FOR A 2001 RAPTOR(SAME MOTOR I THOUGHT) ITS NOT THE RIGHT ONE. SEEMS LIKE EVERYTHING I TRY & BUY AS REPLACEMENT PARTS DOESN'T FIT. I NEED SOME HELP GETTING TO THE BOTTOM OF ALL THIS. CAN ANYONE OFFER SOME GUIDANCE .IS THERE A PARTS LIST FOR THIS BIKE ANYWHERE. I HAVE THE ENGINE SERVICE MANUAL WHICH IS QUITE USELESS. I'M AFRAID I MAY HAVE COME TO THE END OF THE LINE WITH THIS MACHINE OVER A $10 PART.
ironhorse99
Re: OUTPUT SHAFT SEAL
Postby droy » Tue Oct 29, 2013 11:01 am
In the USA it's the seal from a 1995 xt600E. I have one siting on my work bench in Montclair :-D . I'll get you a part number tonight!
Doug in NJ
[b]Gang of Four
1997 Replica
1996 Tour (Track Day Project)
Montclair, NJ USA
droy
Postby edfmaniac » Tue Oct 29, 2013 12:18 pm
The MZ engine can be confusing. The top end is the same as the Raptor 660 but the bottom end shares a lot of parts with the XT600. Grahams has many parts too. Your local Yamaha dealer likely has the oil seal on their shelf. It's a common one.
http://www.motosport.com/dirtbike/oem-p ... 2-25226-00
http://www.grahamsmotorcycles.com/2010% ... EARBOX.htm
grahamsmc49@yahoo.co.uk
Postby ironhorse99 » Tue Oct 29, 2013 8:42 pm
I thank Everyone for your most helpful info. I was starting to think I would never find what I need. Now, is there any chance the clutch I bought 5 yrs ago(i asked for a raptor clutch) will work. I'm thinking not... but who knows.
ironhorse99
Postby edfmaniac » Wed Oct 30, 2013 8:10 am
The Raptor 660 clutch works. Make sure you put the plates in order and there's a special spacer ring in the clutch pack that needs to get reinstalled with the new parts.
Postby ironhorse99 » Wed Oct 30, 2013 9:25 pm
edfmaniac wrote:The Raptor 660 clutch works. Make sure you put the plates in order and there's a special spacer ring in the clutch pack that needs to get reinstalled with the new parts.
Thanks for that info......its about time I got a little good news. :D
ironhorse99
Postby ironhorse99 » Wed Oct 30, 2013 9:28 pm
I attempted to send doug a message but its stuck in my outbox & I have no idea how to send it so I'm posting it here.
Doug: any chance you found that number. I located a Yamaha Tenere XTZ 660 (3YF) parts catalogue and would like to cross ref. that number. If I'm lucky I can use that for all my parts needs and would like to pick up & my local dealer this week end. Thanks, Mike
ironhorse99
Postby DAVID THOMPSON » Thu Oct 31, 2013 8:47 am
mail is left in your outbox till the fellow logs on and sees he has mail
Postby droy » Sun Nov 10, 2013 5:56 pm
Sorry about that delay - Part Number 93102-25218
Enjoy
Doug
[b]Gang of Four
1997 Replica
Montclair, NJ USA
droy
Postby ironhorse99 » Sun Nov 10, 2013 6:19 pm
droy wrote:Sorry about that delay - Part Number 93102-25218
Enjoy
Doug
I went ahead & ordered 93102-25226. It was identical to what was in there.I pushed it in too far & had to order another one(ordered a spare as well) Wonder what difference there is with the one you have. I found a 1995 xt600 parts breakdown as well as a 2001 & the numbers are the same.
ironhorse99
Postby DAVID THOMPSON » Sun Nov 10, 2013 8:58 pm
218 is from a 2003 ttr250
the other number is from a bunch of stuff
Postby Ferd » Wed Nov 27, 2013 1:32 pm
Hey,
Can anyone confirm that I'm understanding this correctly that 93102-25218 is the correct part?
In the middle of go-fast mods to my bike, engine in pieces getting fun stuff. Figure I should take this opportunity to do this right.
TIA!!
Adam
Ferd
Postby edfmaniac » Wed Nov 27, 2013 2:58 pm
All of the parts that I ordered for the left side case on my bike were for the XT600E so my bet is on the part that I recommended in my previous post.
Postby ironhorse99 » Wed Nov 27, 2013 10:22 pm
[quote="Ferd"]Hey,
What is the part??
ironhorse99
Postby DAVID THOMPSON » Wed Nov 27, 2013 11:42 pm
seal at the out put to rear sprocket of transmission
93102-25226-00
Yamaha Parts »1995 Yamaha Parts » XT600EG link below item 022
http://www.2wheelpros.com/oem-parts/199 ... 2-25226-00
and a HERD of yamaha bikes dealer not stocking at least 1 of these needs to open a parts department
Users browsing this forum: No registered users and 172 guests
