660 Engine mods ?'s
660 Engine mods ?'s
Postby BigDog702 » Wed Nov 27, 2013 7:35 pm
Who is the man for internal mod's on the 660's ? :smt006
I've Ported Honda, Suzuki, Kawasaki & a few Euro marks. (2 -Stroke & 4 -stroke, 30 Years Exp. And Learning :?: )
Would be nice to contact a MZ Motor Head on internal mods ? Performance $ Dependability $$$$ Wise ???
What is the Max $ top on Compression without the "Hand Grenade Effect: ?? :mrgreen:
BigDog702
Re: 660 Engine mods ?'s
Postby edfmaniac » Wed Nov 27, 2013 8:20 pm
This should help get you started. Bill J seems to be the authority around here but he has been around a lot less over the last year or more. I think everything he has to say about these engines, almost everything, is written in these forums somewhere. You'd do yourself a favor to go to his profile page and just weed through all of his posts.
viewtopic.php?f=3&t=2172&hilit=mods
search.php?author_id=1418&sr=posts
Postby edfmaniac » Wed Nov 27, 2013 8:30 pm
I just finished up my engine build not too long ago. Here's the basics. Tunebike(Off The Road) carb kit for the stock carbs, carb spacer plate, complete head rebuild with trail or fire road type port, Kibblewhite springs, Megacycle X4 cam, removed decomp and modified cam, 11:1 Wiseco(should have bought a piston from my machinist at Kenz Cycle Tech), removed cush gear on balancer drive and a pair of racing headers with racing can. That probably covers most of it.
The next level of mods involves lightening the flywheel and removing most or all of the counterweight on the balancer shaft. If you do the latter during the first round of mods, you don't need to modify the gear drive for that shaft.
Postby BigDog702 » Wed Jan 01, 2014 12:02 pm
Where are the parts available ?
Contact info. on the Shop mentioned.?
What model did you have Scorp / Baggy ?
BigDog702
Postby edfmaniac » Wed Jan 01, 2014 3:45 pm
BigDog702 wrote:Where are the parts available ?
Parts came from many sources. Give me a list of where you want to start and I'll try to help you track them down. Kenz Cycle Tech can be found online. My engine build was for a Skorp.
Postby AustralianMuZ » Thu Jan 09, 2014 8:12 am
Just a thought mate, it may be worth checking forums to see what dirt bike guys do to their xt660z's to get power.
AustralianMuZ
Postby BigDog702 » Sat Jan 11, 2014 10:50 am
Thanks,
I will look into that ?
May find a good motor recipe ?
Would still like to see a FCR mounted on a Baggy ? :idea:
BigDog702
Postby MZMan723 » Fri Jan 31, 2014 10:43 pm
I have FCR 35s on mine :-D
MZMan723
Users browsing this forum: No registered users and 183 guests
