DIY: cam setting
DIY: cam setting
Postby jbthumper » Sun May 08, 2005 3:17 pm
hey guys!!
can anyone teach me how to set-up those cams for the 125??
from scratch...like....how to loosen the timing chain....
how to check piston position and coordinate with the right cam position??
does the intake cam suppost to feel tighter than the exhaust cam??? :smt017
i thank all in advance. 8)
p/s:pics or diagrams or both :lol: would be great!!
jbthumper
Re: DIY: cam setting(need help)
Postby witttom » Mon May 09, 2005 9:27 am
Wouldn't mind seeing this information myself! :smt045
Tom Witt
78 Suzuki GS750 Cafe Racer
86 Honda Elite 250
98 MZ Baghira 660
99 Triumph Trophy 1200
01 MZ Skorpion 660 Traveller (Sold)
02 MZ 125SM StreetMoto (Sold)
02 Triumph Speed Four
05 Yamaha Grizzly 660
witttom
Postby mphcycles » Mon May 09, 2005 6:22 pm
The 6 mm plug screwed in the frt of crankcase is the TDC locator. Use a 5 allen pin, rotate the crank till the pin drops in. Now youre locked at TDC
The cams have a punch mark, intake is at 9 oclock, exh at 3.Flush wtih head parting surface.
I dont have any pics, but its a doddle of a job. If you have ever timed a four stroke , you can do this guy.
Mike Haven
MPH Cycles
http://www.MPHCYCLES.com
mphcycles
MZ Dealer
Postby jbthumper » Mon May 09, 2005 11:11 pm
info is great!!but i'm too scared to do it without a diagram...very much a newbe on engines...
i think i have a rough idea on how to position the cams....but using the TDC locator,that i have a problem with :oops:
jbthumper
Postby jbthumper » Tue May 10, 2005 11:37 pm
mphcycles wrote:Now youre locked at TDC
i think i managed to find the TDC...i poped in the 5 allen just like u said...turn the crank shaft until it feels somewhat stuck...where the 5 allen had jammed it on TDC...right???
for the intake and exhaust position....is this viewed from tthe crankcase side or charging coil???
jbthumper
Postby witttom » Wed May 11, 2005 1:34 pm
jbthumper wrote:i think i managed to find the TDC...i poped in the 5 allen just like u said...turn the crank shaft until it feels somewhat stuck...where the 5 allen had jammed it on TDC...right???
:smt100 Are you taking pictures while you do this?? :smt064
Tom Witt
86 Honda Elite 250
98 MZ Baghira 660
witttom
Postby jbthumper » Wed May 11, 2005 11:16 pm
i still need to know from which angle to view the cams...you know...the 9 and 3 o'clock thing....will be posting those pics once i know....
jbthumper
Postby bdalameda » Thu May 12, 2005 1:46 am
I would make sure that the 5mm locking bolt is ground down on the end so it can engage the crank TDC point properly. The MZ tool is hardened so that it cannot be sheared off if using to lock the engine. You will be looking at the end of the cams from the mag side of the engine. The forward hole in the cam (bottom edge of the hole should be even with the cam cover gasket surface when the cam is timed properly. The cams are held in place by only a friction lock by tightening the cam sprocket center bolts. When you remove these bolts make sure to clean the threads very well both on the bolt and internal cam threads, use contact cleaner or alchohol. Use only blue threadlocking loctite on the cam sprocket bolts when re installing them, never use the red or you will never get the bolts out again. The engine will actually run better if you time the intake cam forward so that the hole in the cam is about 50% covered by the gasket surface. the engine will pull top gear better and have a more even powerband. Make sure you remove the cam chain tensioner if you are removing the cam sprockets. After making the adjustments to the cam timing remove the crank lock bolt and turn the engine over a couple of times and recheck the timing.
two MZ 125's
Cannondale E440 -Yes Cannondale made motorcycles!
KTM 380
Yamaha TTR 125
owned 26 bikes over 36 years
bdalameda
Postby jbthumper » Thu May 12, 2005 1:20 pm
Roger that. :-D Thanks man!
here are the werx that i did...
fisrt of all i just pop open the head cover...
then...[/img]
Open the magnet coil cover
jbthumper
Postby jbthumper » Sat May 28, 2005 5:47 am
Then,unscrew the allen plug in front with number6...
pop in number5 allen
jbthumper
Postby jbthumper » Sat May 28, 2005 5:51 am
with pushing the number5 allen in,rotate the magnet(PIC 1) until the number5 drops a bit deeper in the crank...you will feel the restriction on the magnet...this is the TDC position
jbthumper
Postby jbthumper » Sat May 28, 2005 6:03 am
loosen the cam sprocket like so...
(do on both cams if you need to set both)
jbthumper
Postby jbthumper » Sat May 28, 2005 6:04 am
i think you guys can follow fom what bdalameda says on the position...
don't forget to tighten them cams up...
take out the number5 allen and spinnnn the magnet....
jbthumper
Postby jbthumper » Sat May 28, 2005 6:07 am
DONE!!
i thank all of you guys that helped me and those who took their time to see these pictures!!(sounds like something from the Grammy Awards..lol)
jbthumper
Mystery wheel in the background...
Postby jawzx » Sat May 28, 2005 9:42 am
Hey JB, I can't quite tell 'cuz it's out of focus, and a little low resolution, but is that an Alfa Romeo wheel I see in the background?
Nice pictures of the job by the way, very helpfull!
2002 125-SM
jawzx
Return to 125 cc
