660 Clutch assembly advice please
Postby Chalks » Mon Dec 02, 2013 6:02 am
Hi All,
I need some advice please. I'm building a 660 back up from a box of parts.
I've slid the clutch basket onto the shaft and according to Grahams parts fiche there's a splined thrust washer that fits next between the basket and the inner clutch hub.
Although this washer is splined when fitted it passes the splines on the shaft then is able to spin freely on a recess in the shaft (a smaller diameter than the inside of the thrust washer)
Is this correct or am I doing something wrong ? ? ?
Chalks
Re: 660 Clutch assembly advice please
Postby edfmaniac » Mon Dec 02, 2013 10:38 am
That sounds familiar. I recall it fitting in a manner that didn't quite seem to make sense but I was sure that it came apart the same way I was assembling it.
Postby Chalks » Tue Dec 03, 2013 10:45 am
Many thanks, just waiting for a gasket now so I fire the old girl up.
Chalks
Postby den » Tue Dec 03, 2013 11:52 am
http://youtu.be/T8M-m0i3uWI
i noticed the same when i did he gear mod ,, look at my video,,i just assembled it as i found it and its working fine,
be aware tightening the clutch spring screws,,theyll strip threads
den
Postby Chalks » Sat Dec 07, 2013 11:35 am
Thanks for the info. It's now back together and working perfectly.
Chalks
Users browsing this forum: Bing [Bot] and 38 guests
