99 Skorpion Sport
Re: 99 Skorpion Sport
Postby AustralianMuZ » Sun Jan 05, 2014 11:43 pm
Cheers for that, I just contacted them so see how we go :)
Could you send me a pic or 2 of your levers mate?
AustralianMuZ
Postby hb7 » Sun Jan 05, 2014 11:57 pm
The stock levers :
hb7
Postby AustralianMuZ » Mon Jan 06, 2014 5:53 pm
Has anyone replaced the rear master cylinder with a non mz item? Just trying to work out what models fit etc
AustralianMuZ
Postby hb7 » Mon Jan 06, 2014 6:19 pm
Listen don't get stampeded into replacing perfectly good kit, if it's properly adjusted and lubricated.
I have been riding and servicing this model Skorp for 10+ years.....
It's the same type as various Duc Monster use from Brembo.
hb7
Postby AustralianMuZ » Mon Jan 06, 2014 7:18 pm
Only reason why I am swapping the master is because it has fallen apart. Every now and then when I go out to the shed in the morning the rear brake lever is lifted right up and the piston has come half out of the cylinder. The bike was dropped on the right hand side at some stage in its life and the master was hit
AustralianMuZ
Postby DAVID THOMPSON » Mon Jan 06, 2014 11:15 pm
sounds like there is air in the system and the clip that holds the master cylinder piston in is missing..
and its also maladjusted where the fluid can not flow back into the reservoir tank when the peddle is at a proper rest point
and as the day warms up the piston moves out as the fluid expands with no way to get into the reservoir
..if the clip was there then we would have a rear brake locked up on a hot day
Postby AustralianMuZ » Wed Jan 08, 2014 5:01 am
I reckon you're spot on as when the weather gets hotter later in the day the rear brake lever pushes up further, on another note I may have just scored a complete Ducati 996 fairing for the old girl
AustralianMuZ
Postby AustralianMuZ » Thu Jan 23, 2014 6:34 pm
Well I've got the new clip ons and ducati fairing but I'm undecided if I'll just use the top as a bikini or try the whole thing. Also at the end of April the bike will be my dedicated track bike as a zx7r will be my street bike if things keep looking up.
Has anyone used racetech 'race fork springs'?
AustralianMuZ
Postby hb7 » Thu Jan 23, 2014 6:42 pm
I don't think a full fairing does anything for scorpion with a top speed of 95.....mph
Or at least that is my understanding
hb7
Postby AustralianMuZ » Thu Jan 23, 2014 8:02 pm
Yeah that's another reason why I was thinking of just running the top fairing. Can't wait to run it around mallala to see how the old girl goes.
AustralianMuZ
Postby AustralianMuZ » Tue Feb 25, 2014 1:39 am
My skorpion has a really hard crunch from 1st to 2nd all of a sudden and seems a bit crunchy going up through the gears. Any idea what it could be?
AustralianMuZ
Postby edfmaniac » Tue Feb 25, 2014 2:12 am
Check the play in your clutch cable. If you have too much slack, the clutch won't disengage completely and shifting becomes more difficult.
Postby AustralianMuZ » Thu Feb 27, 2014 4:30 am
It's turned out to be a bent shift fork so the motor is coming out for a freshen up while the fork is replaced.
Is there a hardcopy of a manual for the 660?
AustralianMuZ
Postby billr » Thu Mar 06, 2014 1:37 pm
AustralianMuZ wrote:It's turned out to be a bent shift fork so the motor is coming out for a freshen up while the fork is replaced.
Go to Yahoo.com, sign-up, look for and join the MZ Owners Group (MZOG).
PDF files of all the manuals there.
Bill R
billr
Previous
Users browsing this forum: Google [Bot] and 31 guests
