Enrichment cable removal
Postby Wailpilot » Fri Jan 17, 2014 3:11 am
Hi guys
Anyone know how to remove the enrichment cable from the carby?
Wailpilot, Vic Oz
Wailpilot
Re: Enrichment cable removal
Postby DAVID THOMPSON » Fri Jan 17, 2014 8:47 am
Depends on carb
Most have a fitting thats made of brass that screws in ..
It is more of an enrichment valve than a choke..
Its surface is rubber covered and can cause problems .also the brass valve gets dirty and sticks
When removed from carb it is spring loaded and comes off the cable
Watch how its put together its several small parts
Dave
Postby edfmaniac » Fri Jan 17, 2014 12:32 pm
If memory serves me correctly, there is a rubber boot that slides back to expose a brass hex shaped fitting. Unscrew that fitting and the assembly comes out. I replaced my stock unit with the XT600 plunger style, no cable. :)
Postby Wailpilot » Fri Jan 17, 2014 11:15 pm
Thanx Guys
Wailpilot
Postby breakwellmz » Mon Jan 20, 2014 3:07 am
edfmaniac wrote:If memory serves me correctly, there is a rubber boot that slides back to expose a brass hex shaped fitting. Unscrew that fitting and the assembly comes out. I replaced my stock unit with the XT600 plunger style, no cable. :)
Hi
I`m very interested in doing the same,can you tell me more please?
Cheers
Postby edfmaniac » Mon Jan 20, 2014 8:51 pm
This part number is the whole assembly. Just pull your old cable and mechanism and screw in this one. 2KF-14371-01-00
Postby edfmaniac » Mon Jan 20, 2014 8:52 pm
Here's another thread on the topic. viewtopic.php?f=3&t=6201
Postby breakwellmz » Tue Jan 21, 2014 4:23 am
Thanks a lot for that.
Bloody expensive though!
Cheers
Postby edfmaniac » Tue Jan 21, 2014 8:55 am
Look around for a deal. I paid about $45 US for mine.
Users browsing this forum: breakwellmz and 32 guests
