ETZ 250 owner . . . . again
Re: ETZ 250 owner . . . . again
Postby DAVID THOMPSON » Wed Jan 22, 2014 10:44 am
from there USA web site
· Premium mineral based gear oil.
· Developed for use in 2-stroke road and off-road transmissions.
· Can be used in all wet clutch systems including Slipper and Rekluse types.
· Meets API-GL3 and GL4 requirements.
· SAE rating - Gearbox 75W-80.
· SAE rating - Engine 10W-40.
Postby Guesi » Wed Jan 22, 2014 11:05 am
O.k.
Then it should be no problem to use it...
Guesi Motorradteile
MZ spare parts
Postby Eric Frith » Wed Jan 22, 2014 12:01 pm
I use it in my ETZ125 and it's perfect.
Eric Frith
Postby Lone-Wolf » Wed Jan 22, 2014 12:55 pm
Wotcha.
The bike did it's first "shakedown" run today. A 50 mile round trip. Only minor niggles to sort.
1. - The petrol tank is very dirty inside, or should I say "Was very dirty" - removed it and gave it a good clean. No more blocked fuel outlets, I hope.
2. - The gear lever needed moving down by about 1½" - now done.
3. - The clutch seems to be freeing off nicely now, but neutral is still tricky to find from a stand still - I'll chase some of this Silkolene Light Gear Oil and see what happens.
Here we are on a rather chilly January day, down by the river Trent at KIng's Bromley.
Lone-Wolf
Postby DAVID THOMPSON » Wed Jan 22, 2014 6:04 pm
Had a Yamaha YM1 years ago neutral was hard to find ...if not hard to find neutral it slipped at high speed...
when sorted out the lever was not pulling the clutch cable a full stroke before it hit the hand grip
i bent the lever just a bit for more PULL Distance and the problem went away
Dave
Postby CharlieCeng » Sat Jan 25, 2014 12:59 pm
I saw your gear change mods on the Bantam site LW. Impressive!
cheers, Simes - '78 MZ TS250/1, '51 Hercules Cyclemaster, '58 Huntmaster, Masquerading D3, Square Four Mk1 http://ariel-square-four.blogspot.com
CharlieCeng
Postby Lone-Wolf » Sat Jan 25, 2014 6:14 pm
CharlieCeng wrote:I saw your gear change mods on the Bantam site LW. Impressive!
Wotcha.
These two stroke owners get everywhere :smt006 :-D
Lone-Wolf
Postby Lone-Wolf » Tue Feb 04, 2014 7:10 pm
Wotcha.
Now that the petrol tank has been cleaned out for the second time ( that'll teach me to do it properly to start with ) the MZ seems to be running fine. The right foot shift is working excellently and the neutral is getting easier to find - possibly due to me using this 'ere Silkolene Light Gear oil . . . . . . . even the lights work :-D
http://www.youtube.com/watch?v=UVyeyWhnwcY
Lone-Wolf
Postby Lone-Wolf » Thu Feb 06, 2014 7:01 pm
Wotcha.
Me and my big mouth :-D
I said "Even the lights work" - - - - - that should say "Even the lights worked" :shock:
Had to go and buy a new headlight bulb today - will the expense never end :wink:
Lone-Wolf
Postby DAVID THOMPSON » Thu Feb 06, 2014 10:04 pm
"will the expense never end"
its worse when you have several hobby's
i just spent almost 100 usd$ on a DDS vfo kit to repair one of my old radios
Postby Andy_C » Fri Mar 28, 2014 3:23 pm
Hi there - are you the same lone wolf that posts on the Hitchcocks forum ?
I used to post there quite often when I had my Bullet 612 - long gone now.
I recently bought an ETZ 301 - has exactly the same leak as yours - now I knwo how to fix it !!
Cheers.
Andy_C
Postby Lone-Wolf » Sat Mar 29, 2014 4:57 pm
Wotcha.
Yep - same one as on the Enfield forum . . . . still got my 570cc bullet. . . . have not laid a spanner on it in anger since 2007 :shock:
ENFIELD BULLET
Lone-Wolf
Postby DAVID THOMPSON » Sun Mar 30, 2014 8:10 am
after reading about your bullet i know why in 2002 i bought an MZ rt 125 from the r/e dealer
in erie pa. usa
:smt040
but i learned years ago with a Triumph tiger cub 1956 model
fifty years later there is a little space in my brain that screams "NO MORE ENGLISH BIKES"
Postby Lone-Wolf » Mon Mar 31, 2014 6:30 pm
Wotcha.
Took the bike out for a 200 mile plus "shakedown" run.
Ended up having dinner at Abergavenny - taking the scenic route over the Gospel Pass.
Went into "speed crazed loon" mode on the way back - not quite sure how fast I went 'cos I ran out of digits on the clock :oops:
The bike did everything I asked of it, and still gave me around 60 mpg.
Lone-Wolf
Postby Tony the Skin » Mon Apr 21, 2014 4:22 am
Great stuff. Really good to see you having a good time on it.
Tony the Skin
