What Oil
What Oil
Postby MichaelTorre » Mon Feb 17, 2014 9:43 pm
I am fixing to fill my 4speed TS250 transmission. Made in 1974.
The East German manual specifies something I don't
recognize.
I am in the States so I have to have a U.S. specific product.
Help?
Thanks,
M
MichaelTorre
Re: What Oil
Postby DAVID THOMPSON » Mon Feb 17, 2014 9:49 pm
what year is the bike
Re: What Oil
Postby MichaelTorre » Tue Feb 18, 2014 1:02 am
Edited to say 1974.
MichaelTorre
Re: What Oil
Postby arry_b » Tue Feb 18, 2014 7:30 am
Year doesn't matter, all the two strokes use a straight EP80 oil in the 'box.
TS250 uses 900ml of the stuff.
arry_b
Re: What Oil
Postby MichaelTorre » Tue Feb 18, 2014 4:07 pm
Ep"- 80"
Is that extreme pressure 80wt ?
It is available in 75/90 at or 80 wt over here.
M
MichaelTorre
Re: What Oil
Postby Blurredman » Tue Feb 18, 2014 5:37 pm
Don't forget, GL3/4. Do not put the more common GL5 varient in. This will swell the cork clutch plates. No damage short term however, though the clutch will be completely fused if left a few hours, and can make pulling away for the first time difficult. And in my case, it pulled the chain, and thus rear axle to the front of the swingarm adjustment area, due to the adjuster going through the back of the swingarm into said adjustment gap.
It will state clearly on the front, or if you read the back, the specification it is. EP is unfortunately much more common than SAE, due to it being usable in both conditions. As long as the weight is around about 80 it'll be fine. But remember, GL3/4 only, NOT GL5. Semi Synthetic is also good to use.
Re: What Oil
Postby DAVID THOMPSON » Tue Feb 18, 2014 7:52 pm
check this link
its what all the fellows here use in there old dirt 2 smokers
http://www.silkoleneusa.com/gear_oil.as ... ID=1048908
the first item may interest you
Re: What Oil
Postby MichaelTorre » Tue Feb 18, 2014 10:25 pm
I am in west central Missouri.
Miles and miles and miles of corn or soy..........cool.....but,
My supply house is going to be a combine and tractor store , or NAPA.
I have to remember gl3-4.
( I wonder how fast the 250 is going to go on the flats?. If it can't do 70 then I will possibly be
run over by a little old lady. The speed limits out here are high.)
M
MichaelTorre
Re: What Oil
Postby DAVID THOMPSON » Wed Feb 19, 2014 1:31 am
napa may be able to get it or a local bike shop
i have been to your state several times on my way to Colorado
the problem i had each time was the rain storms wanted to wash me off the bike ..so any kind of speed
was not reached ,,,
they say its "THE SHOW ME STATE" yes show me a dry spot the next time i go through it
11 times on a bike and 2 in a car and rain in both directions each time..
:smt040 :smt023
Re: What Oil
Postby MichaelTorre » Wed Feb 19, 2014 6:23 pm
you have to visit after June.
It doesn't rain at all after that.
I am betting you drove to in the spring when the dangerous
weather is upon us.
M
MichaelTorre
Users browsing this forum: Google [Bot] and 5 guests
