Mz etz 251 oil change
Postby jackotom54 » Mon Feb 24, 2014 1:38 pm
Hi, have just started to do some work on my MZ Etz 251.
I went to change the oil and removed the Gear selector detent spring will ball bearing by mistake ?
I re-fitted it then removed to make sure the bearing was still on the spring which it was.
So I re-fitted it again.
I started the bike and the gears seemed ok and the neutral light went of.
Does anyone know if this should be ok as I don't want to have to strip the engine.
Thanks dave
Jackotom54@gmail.com
jackotom54
Re: Mz etz 251 oil change
Postby arry_b » Mon Feb 24, 2014 1:44 pm
It'll be fine - as you've found out.
There's a lot of rubbish spoken about the doom and destruction caused by accidentally removing the dedent ball and spring. If you've ever split a five speed box, you'll see what damage removing it can cause. i.e. none!
arry_b
Postby jackotom54 » Mon Feb 24, 2014 2:42 pm
Hi, thanks for that.
Dave.
jackotom54
Postby Lpo90 » Tue Feb 25, 2014 2:13 pm
Did the same to my 250 etz popped it straight back in and havnt had a problem, think iv heard if you change gear with the ball out May cause problems.
Lpo90
Postby arry_b » Tue Feb 25, 2014 5:18 pm
Nope, change gear as much as you like, it'll make no difference. It's one of the great MZ myths that TERRIBLE THINGS will happen if you take the dedent plunger out accidentally.
All the bearing on a spring does is make neutral a bit less difficult to find. Gear indexing happens at the end of the selector drum by a cam and roller mechanism.
arry_b
Postby Blurredman » Mon Mar 03, 2014 7:46 am
I wonder why they made it a removable item. To replace the spring at specific intervals? :lol:
Sometimes I take it out as part of the oil change. Alot of gunk can collect in this region.
Postby arry_b » Tue Mar 04, 2014 2:14 pm
It's removable to make assembling the 'box easier. And, yes, it's a good idea to remove it occasionally and wash the crud out of the area.
arry_b
