rear pad change on baghira
Postby duncmac » Fri May 16, 2014 11:14 am
Whats the right order of things to undo?
Do I undo the two close together bolts first, then unbolt the caliper from the holder?
Sorry for the vagueness and thanks in advance for any help!
MZ Baghira 2002 - Silver
CBR 600 FY 2002 - Tri colour
duncmac
Re: rear pad change on baghira
Postby Gobsheen » Tue May 27, 2014 1:01 pm
Bumping cause I'm interested in knowing how to change the rear pads on my Mastiff. I had a quick look but didn't find a how-to
Gobsheen
MZ Mastiff
Gobsheen
Postby den » Tue May 27, 2014 1:34 pm
from memory just undo the bolts that allow it to be removed from the disk,,pull a spring clip.use a screw driver while the old pads are in place to lever press back the pistons,the add the new ones with a little copper paste on the back.refit,,
den
Users browsing this forum: breakwellmz and 32 guests
