Skorpian; Different speedo and tacho
Postby freeterri » Sun Jun 08, 2014 4:07 pm
Can anyone advise me what I can use to replace my clocks, on my Skorpian Sport, as they are both faulty, the rev counter has given up the ghost and the speedo just wavers about...apparently a common fault?
freeterri
Re: Skorpian; Different speedo and tacho
Postby DAVID THOMPSON » Sun Jun 08, 2014 4:48 pm
contact link
http://www.trailtech.net/digital-gauges/endurance-ii
or just mount a cheap gps
a lighted one would be nice
Postby Chalks » Mon Jun 09, 2014 1:46 am
I spotted these on Ebay:
eBay item number:151320472487
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 1320472487
Chalks
Postby arry_b » Mon Jun 09, 2014 5:18 am
Duff tacho is endemic to the Skorpions. Fortunately, a tacho on a big single that revs as low as the 660 motor does is superfluous so can be ignored. No-one rides a Skorp looking at the tacho, I cover mine with route sheets when I'm touring, that's far more useful.
Wavering speedos aren't common though. Have you tried the simple things first and lubed the cable and drive?
arry_b
Postby Old Dog » Mon Jun 09, 2014 7:07 am
I think you're right, I would remove inspect and lube or replace the cable - if the cable is OK then I would wonder about the drive in the wheel.
All the best
Old Dog
Old Dog
Postby UNNA » Sat Jul 19, 2014 10:56 pm
My rev counter was behaving like a metronome with the needle constantly swinging from side to side. After having it fully repaired the problem didn't go away so I took the bike in to the instrument repair shop. They found the steel plate the speedo and rev counter sit on was causing the rev counter plug to vibrate. I drilled a large clearance hole under the plug so the plug doesn't sit against the plate any more. Problem solved.
UNNA
Postby basser23 » Sun Jul 20, 2014 8:53 am
Very interesting cure...I wonder if all the Skorp tacho problems are related to this...may have to experiment..as mine does the usual shakey needle
basser23
Postby DAVID THOMPSON » Sun Jul 20, 2014 9:48 am
the tach on my rt 125 was acting up for a while ..then the whole bike died
the plug where the charge system plugs into the voltage regulator had died
the ignition box was getting intermittent power
the plastic of the plug had just got old and hot and turned to white powder
i did away with the plug and connectors and just hard soldered it in and used heat shrink tube on the splice
all has been ok since ...but you will probably hear me CURSE the next time i have to take it all apart
Postby Nils D » Mon Aug 18, 2014 7:53 pm
I've spent ages trying, and quiet a lot of money, to get the tacho not being totally hysterical.
When I've put my hand on it I've felt that the whole dashboard has been vibrating a lot. So I removed the three bolts holding the dashboard to the steel-plate, put in some pieces of sponge and tied a string around it - and now I have a working tachometer!
Maybe I could find a way to replace the original rubber bussings that are more flexible and would allow a far better way protect the dashboard from the vibrations.
Skorpion Traveller 96
Nils D
Users browsing this forum: No registered users and 113 guests
