MZ 125 SM Problem
MZ 125 SM Problem
Postby Treesrgreen » Sat Jul 05, 2014 3:48 pm
I recreantly brought MZ 125 SM 2005 and I'm not getting any spark at all. I think it might be the CDI does anyone know where I can get a CDI from?
Treesrgreen
Re: MZ 125 SM Problem
Postby DAVID THOMPSON » Sat Jul 05, 2014 4:05 pm
the relay 19 problem if relay 19 not on or its contacts bad then cdi box not getting power
this can also be a bad side stand switch or kill button
Postby Treesrgreen » Sun Jul 06, 2014 4:58 am
DAVID THOMPSON wrote:the relay 19 problem if relay 19 not on or its contacts bad then cdi box not getting power
what is relay 19?
Treesrgreen
Postby DAVID THOMPSON » Sun Jul 06, 2014 11:02 am
give me a day or so and i will send you a PDF file of how to look for the problem
i have not heard too many complaints that a cdi was bad
its always been it was not getting power for some other reason
here is a link to a drawing of the 660 bikes on them its relay 30
it connects the power up when you turn on the key
the relay is not located the same place on an rt125 as a sx or sm
mine is near front of battery not sure where sx or sm it is located
when it works it hooks up a red white wire to a red black wire
i am looking for my camera
right click and save image as to save drawing
download/file.php?id=3717&mode=view
Postby Treesrgreen » Sun Jul 06, 2014 11:24 am
Thank you :D
Treesrgreen
Postby DAVID THOMPSON » Sun Jul 06, 2014 1:59 pm
NOTE
1the kill switch on the right handle bar must be in the on position
2 the bike in neutral
3the sidestand up
then you will have 12v on both red/black and red/white at the relay contacts when the key is on
on my rt125 if it sets for a long time and carb dries out its a bastard to get started when the carb is dried out....
Postby Treesrgreen » Sun Jul 06, 2014 3:55 pm
DAVID THOMPSON wrote:NOTE
3the sidestand up
I've done all that and still no spark, I'm going to take it down my local bike garage tomorrow and see what they have to say
Treesrgreen
Postby XCalsteRX » Sun Jul 06, 2014 6:16 pm
I'm assuming you've tried a new spark plug? If so have you made sure the spark plug has a ground? If not put the side of the spark plug to the frame or engine, be sure not to hold the spark plug whilst doing this or wear some safety gloves otherwise you may get a 12 volt shock ha!
Trying to save you a hefty labour bill!
XCalsteRX
Postby Treesrgreen » Mon Jul 07, 2014 4:54 am
XCalsteRX wrote:I'm assuming you've tried a new spark plug? If so have you made sure the spark plug has a ground? If not put the side of the spark plug to the frame or engine, be sure not to hold the spark plug whilst doing this or wear some safety gloves otherwise you may get a 12 volt shock ha!
I've tried a new plug and I've tried what you suggested only going to the garage because I've run out if ideas
Treesrgreen
Postby XCalsteRX » Mon Jul 07, 2014 6:35 pm
Ahh okay, well I hope they find the fault! I also hope they don't charge you the earth for it to, be sure to let us know what it was if they find anything
XCalsteRX
Postby Treesrgreen » Tue Jul 08, 2014 5:02 am
I Will Do :wink:
Treesrgreen
Postby Treesrgreen » Tue Apr 14, 2015 1:52 pm
XCalsteRX wrote:Ahh okay, well I hope they find the fault! I also hope they don't charge you the earth for it to, be sure to let us know what it was if they find anything
Sorry its late :wink:
Due to a extremely poor wiring loom the CDI was fried.
Had to replace the loom and the CDI
Treesrgreen
Return to 125 cc
Users browsing this forum: No registered users and 92 guests
