by MZFred » Sun Sep 21, 2014 11:10 am
Can any one advise on side stands please, I've recently had 2 repaired but unfortunately they have both ended up broke again! So is there some way of making a good repair or an alternative side stand that will fit, even one on to the frame or suitable brakit/mounting.
MZFred
by DAVID THOMPSON » Sun Sep 21, 2014 2:07 pm
2 cycle or 4 stroke
and there is one for some models that fits at the rear axle on the swing arm
some one set on my rt125 at work and broke mine out of the frame where it mounted
good thing i know how to weld
- Moderator
by den » Sun Sep 21, 2014 2:11 pm
Post a photo of the complete unit. I may retrofit one
With better quality steel.
den
by MZFred » Sun Sep 21, 2014 3:09 pm
Sory folks forgot to say its on a TS250, its the one that fits between the swinging arm and brake plate. So is the issue that they are dissimilar metals e.g. cast and mild steel?
MZFred
by Guesi » Tue Sep 23, 2014 5:12 am
The price for a new one with 2 springs(returns automically) is about 30 Euro.
So I would not weld with the risk of breaking again and damaging the bike....
by Blurredman » Thu Jan 22, 2015 1:11 pm
After purchasing an aftermarket side stand, I found it bend under the weight of the bike.
I got a replacement, from a different factory, that did much of the same.
I got an original from e-Bay which is proper thick steel years ago (and for the same price as an aftermarket) ... No bending
by MichaelTorre » Sat Feb 07, 2015 11:07 pm
The sides stand I got from Guesi, is very sturdy.
You will not be disappointed.
M-
MichaelTorre
